Old 04-05-2007, 03:50 PM
Question Driveshaft retube
I'm taking my DS in to get retubed at englewood DS (unless there is somewhere better) as soon as my u joints come in.
I'm guessing they will know what to retube it with but should I go up in thickness?
Romer, what thickness did you get yours retubed with
I don't want to slow down the 95HP with more rotating mass a whole lot more than I aready have.
Old 04-05-2007, 05:53 PM
.120 for durability. .096 for a little more "street."
frontrange driveline at federal and 285 always does a great job for me.
I've had 3 shafts fixed up/made there and they all are still driveable. (one just has a really worn out slipyoke. nobody's fault.)
Thicknesses:
I destroyed a stock mini-truck shaft on a single rock in lefthand carnage canyon once. I think that was about .060. I drove Boulder to Aurora at 35 mph on that one.
I had that wreck re-tubed by a shop out in Commerce City. That shaft got wrecked again on rocks @ billing's canyon. The tube was smaller in diameter for the last 4 inches after rubbing it on the ledges. It didn't fail, but it sucked driving home to Aurora from Grand Junction on the necked down, slightly bent shaft at 70mph. I think that shaft was .096.
My FrontRange driveline shafts have not dented or broken yet. I told them I plan on parking the truck on the driveshafts and when the guy looked under my truck at the dents/scrapes he understood. So far, the front range shafts have only lost paint and a few grease nipples. I cannot tell the difference in the tubing thicknesses while driving on the road. I say go thick. My current units are .120.
My spare square front driveshaft is .250. That is a little overkill.
KD0FDS
Stephen
Old 04-05-2007, 05:55 PM
Englewood will take care of ya...
Specify Toyota U joints if needed, however. He likes Spicer.
KDRCH
Old 04-05-2007, 06:03 PM
I'm taking in Toyota u-joints when they arrive(hopefully) fri.
so what's stock roughly on oem tubes?
Old 04-05-2007, 06:08 PM
Disappointing
Don't remember, but it's thinner than what he usually uses. "These Toyota u-joints and yokes are fine, but the tube is kinda thin." That's what he told me when he retubed my rear fj40 driveshaft in 2001.
Originally Posted by nakman
Old 04-05-2007, 06:47 PM
Crash's Avatar
Crash Crash is offline
.060" or maybe a hair more for OEM. .120" is really stout and can withstand serious abuse but it then transfers the abuse to the next part in the chain - the U-joints and then to the pinion or t/case bearings. Two different drive train shops I have worked with may prefer to sell you their favorite brand u-joints but both have had nothing but the highest regard for Toyota joints. With regular maintenance they are virtually bullet proof. Imagine that!
Old 04-05-2007, 09:04 PM
I went .120 on my 100 rear. Tagged it once and it's still straight and balanced.
Old 04-05-2007, 09:16 PM
I think stock is .065". I did .120 wall on my 80 and the Tom Woods shafts on my 40 are .120 as well. It takes a lot to dent .120 wall! Stock will dent very easy and once it dents it will twist soon after!
Old 04-05-2007, 09:53 PM
Romer Romer is offline
I don't recall the exact number. I know I went there with a recommendation from Mud and they talked me out of it saying it was too thick. Those guys know their stuff and I went with what they thought.
Old 04-05-2007, 10:57 PM
If they said it was too thick that tells me they didn't stock what you asked for!
