Old 04-07-2007, 08:08 AM
IanB's Avatar
IanB IanB is offline
Default Diff pinion depth SST
Does anyone have the SST for setting the pinion depth on a 40 diff? SST 09530-35010
1976 FJ-40
2001 UZJ-100
Old 04-07-2007, 09:01 AM
Three Wheel Ben's Avatar
Althought it is very nice to use. You don't have to have it. All the Toyota dealers I've worked at these are under inches of dust if they are even there at all, good luck.
You can build without it it just takes more trial and error of assembling and disassembling the diff. Little bit more time if using a solid spacer.
Fyi the shim for pinion depth is either under the large bearing race of on the pinion shaft under the actual bearing. Doesn't matter which way you do it just do one or the other not both.
KC0ZBI
Old 04-07-2007, 09:56 AM
Ian,
Aftermarket gears have a suggested depth scribed on the pinion. What I do is put the stock shims back on with the large pinion bearing and set it in the housing. The suggested depth is taken from the pinion face to the centerline of the carrier. Place a small straight edge accross the carrier bearing mating surface and use a depth guage to check the depth to the pinion. This will let you know a close approximation of how much to shim or unshim to get to your beginning depth. Gears are a PITA the first few times but the more you do them the easier they are! Have fun and I'm very happy to see you doing this yourself!
Old 04-07-2007, 01:21 PM
you home today?
Old 04-07-2007, 02:06 PM
IanB's Avatar
Originally Posted by Rezarf View Post
you home today?
Yah, workin on the 40 all day.
1976 FJ-40
2001 UZJ-100
Old 04-07-2007, 02:09 PM
IanB's Avatar
Well I hit a wall today, the old diff had no washers in it and only one badly torn up shim. Even though the rebuild kit for Cruiser Outfitters comes with a wide variety of shims there are no washers. So I ordered up a few today. I'll have to do the trial and error process now.
1976 FJ-40
2001 UZJ-100
Old 04-07-2007, 03:18 PM
how's the 40 coming along Ian?
can't wait to get mine in the garage and get back at it
jim
Old 04-07-2007, 03:23 PM
IanB's Avatar
jim
Slooooooooooooooooooooooooooooow. Basically nothing has happened during ski season, I am hoping to make some progress once the snow melts though.
How goes the biz?
1976 FJ-40
2001 UZJ-100
Old 04-07-2007, 05:32 PM
How goes the biz?
so how was skiing this year?
man i need to get my butt back on the board, maybe next year i'll haul my boy up to berthoud pass and strap the snowboards on
Just getting all set up this last week.
i'm ready to roll now!
Old 04-08-2007, 06:59 AM
IanB's Avatar
50 days so far but the snow is melting fast.
1976 FJ-40
2001 UZJ-100
