Old 04-09-2007, 01:02 PM
Here is how I did mine. It sits a tad high but actually is a good compromise when the rope is all played out.
I used 3/8x1.5" strap iron. The winch boltls go through it sandwiching it in. I then located the fairlead holes and taped thread into the plates to hold the fairlead tight. I actually had to space my 12.5k winch back anyway to fit so it worked out great.
Old 04-09-2007, 01:42 PM
Thanks for the pics UB...
I've got spacers in there to fit the XD9000 already so I could theoretically tap into those...But I don't have the experience to do that and would have to go buy the tools to do so.
And I would still have to drill into the bull bar for the hawse fairlead correct?
Does putting the winch the 1/2" to 3/8" higher on the bull bar in order to utilize the top winch holes make that much difference overall? Spanky made the point of keeping the winch low so it is closer level wise to the frame rails which makes sense. I'll have to look tonight to see where the winch would sit in relation to the frame rails using the upper holes...
Have I beat this issue to death yet?
Old 04-09-2007, 03:28 PM
If it will work to raise the winch then do it without looking back! I'm guessing it will only fit the lower holes.
Old 04-10-2007, 01:08 PM
In case anyone is wondering, NEVER doubt the wisdom of UB
Farted around with the ARB and winch last night and the winch can NOT (XD9000 anyway) mount to the upper holes unless you want to cut the ARB . The motor clears (i.e. sits just under) one of the support pieces by maybe 1/4". So, unless I want to notch this support piece that winch isn't going up.
So, I'm just leaving the thing as is for now and will see how it works. Few options would be:
  1. Drill new lower holes through the ARB and into the spacers for just the fairlead. Then tap them to accept the bolts
  2. Buy a different Hawse fairlead (like UB posted) designed for feet first winch mounting like on the ARB
  3. Talk Christo into designing and making a new bling fairlead with the holes offset lower like the OKOffroad one
I like option #3 best...hint hint Christo
Other thing I noticed is that on the XD9000 the motor is on the left (M12000 motor is on the right). Would be PERFECT if I had a dual battery setup. But the single battery on the LX is on the right. So, now I'm not sure my existing cables will reach so I may arrive in Moab with a bling ARB, winch, fairlead, synthetic rope, that doesn't actually work.
On a side note, I have the front end of my FJ40 all apart. I took the winch off and then decided to take the winch mount off (what a royal PITA!) which required me to take the bib off and disassemble most of the front end. My wife is starting to wonder if I've gone mad
So, if anyone is interested I might have a winch mount plate (feet down design), roller fairlead, and high lift jack towers avail for sale. I believe the bumper is spoken for already.
How it looked before disassembly.
Old 10-30-2010, 10:33 PM
coax's Avatar
coax coax is offline
Thread resurrection +1!
To paraphrase Pink Floyd, in a momentary lapse of financial reason I have purchased a winch. (EP9). So far the install is about as un-plug-and-play as possible. (I'll do a separate install thread).
However, due to the fairlead that came with the winch not compatible with the ARB, I am thinking of going synthetic rope since I eventually wanted to do that anyway, and rather than buy a new Warn Fairlead, I'd rather get a hawse fairlead, and sell my wire rope while new for 40 bucks or something.
So, question for you guys that are running hawse fairleads with the ARB. Do you ever run into problems (when the pull is angled upward) where the rope rubs against that horizontal fairlead support on the ARB? Seems like since the hawse is stuck back a bit further it may hit the rope at an upward pull? ( I know I'll have to run an offset hawse like slee's, but just don't really want to have to start cutting on the bumper. I think I'd go delrin rollers before that). Also any problems with having one bolt/nut clamp the (hawse | arb plate | winch ) together? The winch did come with 10.9 hardware...
-Corey
'74 project pig (sold)
Old 10-31-2010, 06:02 AM
[*]Talk Christo into designing and making a new bling fairlead with the holes offset lower like the OKOffroad one [/list]I like option #3 best...hint hint Christo
ummmm, he already does make those...have you visited sleeoffroad.com?
Old 10-31-2010, 06:12 AM
Miss Ige, did you happen to notice the date of Jeff's post?
Old 10-31-2010, 09:45 AM
coax's Avatar
LOL maybe I should have started a new thread but Jeff's post was titled exactly what I would have named mine, I am just years late to this party. (And btw, I searched the internets with no luck for 15 minutes on the subject of hawse leads on arb's before I found Jeff's thread. )
-Corey
Old 10-31-2010, 09:58 AM
Caribou Sandstorm's Avatar
Didn't notice the date either Ige..Just reading along...
BTW, I have the Slee fairleed with the off set lower holes and syn line from Viking off road, works great. My original Hawes Fairleed did not fit my FJC ARB bumper.
Chris
2001 UZJ100 Mel's rig now!
2016 Tacoma TRD OR DBCSB
TLCA# 18518
KD0IFE
FJSummit.org
Off Road Pics
Old 10-31-2010, 08:13 PM
Corey you're alright man.
