Old 04-12-2007, 01:26 PM
Default 2 ga Cable/Wire Crimping
Discovered last night that the positive connector for my winch going to the battery is fubar. Connector looked weak and thin to begin with but with all of the pushing and prodding to route the cable to the battery the connector gave up the ghost.
So, now I guess I need to buy a new connector and a crimper, but as usual I know nothing about these. I've got your typical little electrical crimper deal for 14-20 ga wire but nothing big enough to do the 2 ga winch wire.
Is this what I need
http://www.mytoolstore.com/ideal/ide12-08.html
I read an old thread by Red Chili about relocating batteries to the rear on a 4Runner where he talked about getting a crimper that wasn't too expensive so I'm hoping that means I just don't know what I should be looking for.
TIA
Old 04-12-2007, 01:32 PM
Fill the lug with solder 1/-3/4 and insert cable end. Don't burn yourself. Then i put a shrink fit insulator on the end.
WØREK
Old 04-12-2007, 01:40 PM
Hmmm...that holds ok? There won't be much (shouldn't be) stress on the cable but some of the ones for the winch look like the cable was fed in, crimped, and then a hole punched to make the "ring" or eye. I think my positive lead was a PO "redo" as the width of the metal on the ring isn't more than 1/8" wide, and now it is split/broken. HONEST. Tragic really as all the others are nice and thick.
Old 04-12-2007, 01:57 PM
Hants's Avatar
Hants Hants is offline
Here's a variety from DelCity:
http://www.delcity.net/delcity/servl...tid=229&page=1
The Die Cast Terminal Crimping Tool at about $150 (typical price) crimps all the way around and gives a (much) better mechanical connection than the $50 hammer/vice crimpers.
I've been eying it for my upcoming dual-battery/winch project. If you end up wanting to buy one, I'd consider splitting the cost with you
"Wanna race?" - Bill Morgan
Old 04-12-2007, 01:58 PM
That's how I do mine.. I havent' had any issues. If your cable is short it might pull on it or if you use really stiff cable with less strands. Othewise that's how I did all my new cable connections for the new used winch and redoing my grounds on the rig.
WØREK
Old 04-12-2007, 03:02 PM
if you want to crimp it also, you can pound it in with a chisel, but the solder and heat shrink has worked for me for years.
Old 04-12-2007, 04:05 PM
trucruiser trucruiser is offline
I have used the little crimper that they supply when you buy a custom set of ignition wires, tap with a hammer.
If you have never purchased a set of wires you have to crimp the ends on then you may not know what im talking about.
Old 04-12-2007, 04:14 PM
Alrighty...I'm going to try the solder/heat shrink trick first
I'm also going to run over to that JL Audio distributor just down the road from me as they have some really cool bling stuff that might work for a long term. I want to run the power for the winch, lights, and power center (secodary fuse block for CB, outlets, etc) off there and JL makes something that looks like it would make these connections real slick (see here). Of course no idea how much $$ that bling stuff cost
Hants, as for that crimping tool...That is tempting but I'm got to stay inexpensive for now as the mod fund has taken a serious hit lately
Old 04-12-2007, 04:31 PM
Hants's Avatar
... the mod fund has taken a serious hit lately
I suspect quite a few of us are in that boat right now
Old 04-12-2007, 05:23 PM
Seldom Seen's Avatar
I've been working on mounting my winch in the 4Runner and I decided to mount the control box under the hood, so I'm going to need new cables.
Since the crimpers I had only go up to 6 ga, I figured I'd solder them as well. I did some searching on the marine sites for how-to's. I always defer to the boating crowd, for projects like this, 'cuz I can't think of a harsher environment for electrical connections.
This is what I found out: You must use tinned lugs and cable or be able to tin the lug and cable. Use non-acid flux and non-flux core solder that is formulated for electrical connections. The stuff you would use for soldering copper pipe won't work for making good connections.
All the articles I read DO NOT recommend soldering alone. Soldering, if done right, will make a good electrical connection but will not make a mechanical connection.
All of the how-to's I read highly recommend crimping 1st and then soldering!! Most of the articles stated that if crimping is done right, there is very little room for the solder to flow into anyway and there is little benefit to soldering other than increased water tightness. Dielectric grease and heat shrink will give equal weatherproofness.
Per Red Chili's recommendation I got me one of those hammer crimpers to finish the project and it works great. you are welcome to use it if you want.
I went over to Westmarine, on County Line, this week to pick up more cable and lugs and got to talking to one of the guys in there. Lo-and-behold they have an entire work bench set up for customers to use to make their own cables !!!!! Buy your stuff there and you are welcome to use it. Cutters, strippers and a bench mounted compound leverage crimper, every thing a gearhead would need to get-er-done right!!!!
