Old 05-09-2007, 09:47 AM
Default Air Locker fitting
Anyone know where (or if) I can get this part of the bulkhead fitting? This is the little part where the tube from inside the diff comes together with the blue hose. BTW, this little part is no match for the diff housing-to-garage floor impact when your front diff assembly rolls off your jack as you're trying wrestle it into place...
Old 05-09-2007, 10:04 AM
I believe A&A Tradin' Post may have it. Should be NPT and compression fitting sizes. No kiddin'!
If not, TRBurris@ARBUSA.com should be able to fix you up.
(206) 264-1669
KDěRCH
Old 05-09-2007, 10:42 AM
arb uses odd sizes so i retapped mine to take 1/4" air lines/1/8 npt
Old 05-09-2007, 11:38 AM
Man Jerk Man Jerk is offline
You could always call Steve Cramer (Poser on ih8mud). I'm sure he's got them in stock.
www.lcr4wd.com
Mark Janzen
Member of:
http://www.mntoyx4.com
http://www.coloradolandcruisers.org
86 4runner
Old 05-09-2007, 01:00 PM
Three Wheel Ben's Avatar
Marlin sells them, not local though.
FWIW, my email to this address was bounced and the area code for ARB USA is now (425). I am going to call tech support at ARB and just ask them.
KC0ZBI
Old 05-09-2007, 01:40 PM
Thanks for that. I got the contact info from an article I wrote on 4x4wire.com for Project Blackbean.
I guess no career is permanent! Parts should be easy to get from them, never had a problem.
KDěRCH
Old 05-10-2007, 02:51 AM
McGuckins hardware in boulder. I messed up one of my fittings, went down there, got it out of a bin. Also built my pressure tester that way.
Old 05-10-2007, 05:28 AM
It might be BSP (British Standard Pipe) thread rather than the usual NPT. I ran into that on the solenoid manifold on the ARB compressor.
