Old 05-13-2007, 04:26 PM
Boulder Cruiser's Avatar
Boulder Cruiser Boulder Cruiser is offline
Default The new cruiser
So i just went and picked up that cruiser that was on CL i talked him down to $700. It has New Fenders, aprons, tires, battery, and all four turn signal signals. The PO said that the starter wasn't hooked up right so it doesn't run, Since it doesn't run we strapped it to the trusty highlander. Once we got home i wanted to see if i could bump start it, after a bit it started running, there was SO MUCH SMOKE you couldn't see anything all the neighbors came out and looked in discussed Anyway the rust is minimal, alot better that my other 40, the only problem with it is it doesn't run unless its moving and thrown in gear, when i looked under the hood after pulling it the motor was soaked in oil, my dad said it was spraying out of the bottom, i don't really know much about engines so fixing that is going to be a big problem for me. Any suggestions? Oh and i havent had time to flip the bezel
Old 05-13-2007, 04:37 PM
Few more
Old 05-13-2007, 06:54 PM
cool~
Tear out that Detroit crap and put in an F. Then drive it and enjoy.
Old 05-13-2007, 10:23 PM
Change all the fluids, plugs, wires, cap, air filter, spray some carb cleaner down the carb, check the points and give it a rip...
2f all the way man! 700 bucks is a good deal if you ask me.
Old 05-13-2007, 11:12 PM
Shark Bait's Avatar
Yeah. I'd vote for stock. I probably have most of the motor mounts you'd need.
'11 Tacoma
Old 05-14-2007, 08:47 AM
Rising Sun Webmaster
It will be cheaper to fix what you already have, unless there is a hole in the block. I say fix the Chebbie motor and wheel it.
Old 05-14-2007, 09:05 AM
Vitesse_6's Avatar
Vitesse_6 Vitesse_6 is offline
Wasatch Cruisers
Werd
Nice find, I saw the post on mud
Have fun.
Brian Passey KE7TGH
TLCA #8382
Wasatch Cruisers
Home of the cruiser rings
Old 05-14-2007, 09:37 AM
Engine looks like an early 283 or 327. I'm guessing it has a crank case breather tube instead of a PCV system. The early small blocks ahd slighly offset valve cover mounting bosses that prevent just swapping covers with later model PVC provisions. If you snoop around you might be able to find some aftermarket 'Vette valve covers that had the off set bosses and PVC system. A better option would be to source a later model small block in good running condition and swap it out. You can score carburetted Cheby engines quite cheap unless they are from early 'Vettes of Camero's. If possible score a late 60's truck motor. All early truck motors (and most large station wagons) had 4 bolt mains and camper special trucks all had the 1.94 Camel back heads! (Thats a good thing!)
Colorado Trail Patrol
Stay on the Trail!
Old 05-14-2007, 10:23 AM
Lowest cost option would be finding a carb'd Chevy truck that's on its 2nd engine (they all are, far as I can tell ;-)) and put that engine in it. As gas goes up, old 2WD pickups should become nearly free in price.
I bought a factory-reman 350 (used) for $450 and it tested out great and put my plow truck back on the road for cheap. Being a rarely used truck, I really didn't need a GM factory new engine.
Having said that, I'd find a clean 2F from an FJ60 and stick that in there, but it's likely to be a bit more work. Then you'll have a real cruiser engine with real torque.
Steve
Old 05-14-2007, 04:05 PM
Thanks for the advice guys
Ben, your right it is a 283 from a corvette. The po said it was running until the starter and fuel pump went out, He recently rebuilt the carb & distributor and the engine was professionally installed. I think im going to poke around at it and see if i can fix it myself, if that fails ill start looking into a new motor, which in that case ill get a 2f.
Did 74's come with the stock black wheels? it looks like there's gray under the flaking black.
Thanks again guys!! Im sure ill have alot more questions
