Old 10-27-2005, 09:45 AM
4runner Freak's Avatar
4runner Freak 4runner Freak is offline
Default Toyota shackle jig for SAS
I'm looking for the jig for putting shackle tubes through the frame for a SAS on a '86-'89 4runner.
Hoping for free!
Hoping that someone has them still lying around after they did their SAS.
Thanks
Danny
PM me
Old 10-27-2005, 06:14 PM
What's a "shackle tube"? I thought shackles (and spring pins) are mounted in U-section. Just cut the u section to the size and shape you want, drill the holes for the shackle (or spring) pin, clamp with long vice grips to tack, remove the vice grips and lay your bead.
Old 10-28-2005, 02:12 PM
This is what I am looking for!
Note:
The back end of the front springs are attached to a shackle!
That shackle is bolted through the frame.
To perform a SAS, you must (unless you do shackle under frame) cut a hole in the frame and weld in a tube for the bushings. The jig is made to line up the shackle holes! Hence the need for a jig (or at least to make the work easier).
Old 10-28-2005, 02:57 PM
Default did mine sans Jig. it came out pretty close.
*shrugs* It would have been a lot easier with a jig, but you don't NEED it.
Old 10-28-2005, 05:18 PM
Guess I shoulda paid closer attention to the way my daughter's 85 runner is set up. I know the shackle's in the rear, but I never noticed that the pin went through the frame instead of underneath like Land Cruisers are.
BTW, I couldn't go to wherever that link was, said access denied.
Old 10-29-2005, 01:02 AM
Sorry Rzeppa,
I had posted a pic on my blog, but I guess it wont load.
Here is a link to the pic on the Marlin page.
http://www.marlincrawler.com/images/tubes_jigs_500.jpg
HTML code is On
