Old 05-23-2007, 02:42 PM
FJBen's Avatar
FJBen FJBen is offline
Default Clutch master/slave older cruiser 67
Situation....67 FJ40
slave cylinder died at safeway last night, got towed by my friends sammy :crybaby: (but hey glad to have good friends! )
67 FJ40, 350 sm420
It has the original 67 clutch master/slave 40 years is pretty good part life I suppose. master has some leak marks on firewall...prolly time as well.
Calling Cdan I find that the slave is discontinued but master isn't... His parts book doesn't go back to 67...only 69?
So options are:
A: Buy 74 and later Clutch Master, Slave, hose and make new hardline
B: Buy 71-74 (any difference?) clutch master, Slave, hose and make new hardline
C: SOR has a full update kit for $169.00 ??? http://www.sor.com/sor/cat018.tam?xa...x=cat018%2Etam
TLCA#15530
96 285's OME 's ride
Old 05-23-2007, 03:11 PM
can you rebuild it? check sor for rebuild kits or stuff that will work.
is the master the old metal can style? if you get a new one, can i have it for parts?
Old 05-23-2007, 04:49 PM
FJBen's Avatar
I don't think it's the metal can style. I though rebuilding didn't work so well on those??? I mean that saves a whole lot of money, but does it work???
TLCA#15530
Old 05-23-2007, 04:52 PM
depends on how pitted the inside of the cylinder walls are. i've only rebuilt one slave (no issues on that one), but i've done all my wheel cylinders and a couple brake masters with no probs
Old 05-23-2007, 05:11 PM
You've been more successful than I have, Ige. But that's not surprising!
KDØRCH
Old 05-23-2007, 07:31 PM
maybe it's because i'm building old dinosaur stuff and you're building stuff for them newfangled hotrodding trucks.
Old 05-24-2007, 07:03 AM
treerootCO's Avatar
Event Coordinator
67 was the first year for the plastic reservoirs.
You can fit/cross over almost every year on a 40. Romer's old 40 had a metal can style on his 77. My 78 is running one from a 73, etc. Same applies for the slave.
I rebuilt my 66 clutch master last weekend by taking it apart, honing the cylinder and putting all the old junk back in. Works great and free too.
www.root45.com
www.risingsun4x4club.org
TLCA #14133
Old 05-24-2007, 09:32 AM
<snort>
KDØRCH
Old 05-24-2007, 10:01 AM
You could install a '71 master, cut the tip off the hardline, install a later-style flare fitting, and reflare the pipe. This assumes there's enough hard line to flare it and that you've had good luck making flares.
Long term: I'd put all '71-and-later style parts and make a new hardline from a piece of brake line (comes with flares at both ends) from Advance Auto. My '65 is now all '71-and-later era stuff - '71 MC, brakeline-bent-as-hard-line, new flex-line, and '78 slave cyl. Works great.
Old 05-31-2007, 04:50 PM
FJBen's Avatar
just put a slave on it, and she works fine, we'll see when I post back up in two months that the master went out....
saving money for longs
TLCA#15530
