Old 10-31-2005, 04:17 PM
Snorkel 1's Avatar
Snorkel 1 Snorkel 1 is offline
Originally Posted by powderpig
Sorry to say, i do not remember every one that has traveled through slee offroad. I am no longer with christo. I work for my self up in louisville. Do a mobile service as well as work out of the house. Any way I can help let me know. Does kendals truck still have the blower? later robbie
I know you saw alot of trucks go through, I was just saying thanks again for helping us out on such short notice.
Yes it has the blower and about $16000 in other parts. I am swaping most of the parts to a tan 40th Annivarsary. This way I get to modify it the way I want. This one has a blower also. I plan on a Slee 6 inch lift kit, sliders, rear bumper and 37's. It is a big job. I wanted the ARB lockers so I am going to swap the axles to save some cost plus I just had the front seals and bearings replaced for about $1100 this spring. I wish I could have brought the trucks to you or Slee, not many mechanics have worked on these.
Old 11-07-2005, 11:22 AM
Snorkel 1's Avatar
I can not remember Kendals last name, but he installed most every thing himself when it came to electrical. I beleive he even installed his own tank. These tanks are really nice, made sturdy and will take a bang really well. Your best bet is to talk to Kendal if you can get ahold of him. He really had his own way of doing stuff. We got our tanks at the same time and christo and kendal did the electrical in a unique way and I did it a real easy way (with no circuit board). I beleive we all spiced into the level reading on the dash guage the same way. On the driver side under the dash down by the pedals to the left above the dead pedal you may see a wire spliced(aftermarket) into another wire(stock not super big bundel). this is more than likely the dash wire feed to the fuel guage. There usually was with this install a little switch to the left of the steering wheel (black small square, up and down position not marked). This switch controls what tank you are viewing on the dash guage. the switch with the circuit box controled the fuel pump and the automatic like functions of the stock system that is in Aus.
To find what wires kendal used at the back with the stock wiring diagram you will need the toyota Electrical Wiring Diagram book for the specfic model year you are working on. In most cases the EWD is close enough to work for a couple of model.
The switch you are showning in the picture is a stock toyota sub tank switch for you model year truck(and several years of range). The plug on the end was the way Kendal connected the wires to the truck and the control unit. If you did not trace and pull this control unit you may be SOL on this as the boxes were a custom make and christo may or may not Make another. You would have to contact him. The sender in the aux tank is toyota part and has toyota specfic resistance to match the dash requirement in the 80 series. The fuel pumps we used for this was some from Carquest, and it strictly was a transfer pump(one that could be run dry). it pumps fuel from the aux to the main at about a gal a minute, There also should be an inline fuel filter that you may want to change out at the time you swap. You you need to talk to me you may reach me on my cell 303-884-7813. I no longer work for christo. later robbie
Well I found the circuit board but the shop had already cut it out of the original truck so I have no idea where all the wires are supposed to go. Is there a way to access all wiring diagrams for Toyota switches for this and future mods? Robbie did you have all the functions of Kendall and Christo's set up when you installed your tank the simple way? If so why did they go through all that work? Thanks.
Seth
Old 11-07-2005, 04:55 PM
powderpig's Avatar
The circuit board set up was to allow the pump to auto turn off when the rear tank was empty, and I believe when the main tank was full. I just have a relay that a switch turns on and I watch when the main is full. I have a true transfer pump that does not mind being run dry when the aux tank is empty. real simple.
As for the wiring diagrams, the EWD book toyota sell is about the best, it has all the wireing as well as the connectors so you can be sure you are on the right bundle, it also shows in most cases where these specific connectors can be found.
hope this helps. later robbie
Old 11-08-2005, 01:21 PM
Snorkel 1's Avatar
Thanks Robbie. I think I have the EWD book you are talking about.
I wasn't the one who removed the circuit from Kendall's truck but I think it was still wired in at the time. But my pump would not shut off automatically. This would be a nice feature I guess but not necessary. Maybe I will contact Slee to see if they have more info if I can't figure it out. I'll post back in a day or two.
Seth
