Old 06-10-2007, 11:49 PM
Originally Posted by ScaldedDog View Post
It's hard to tell from the photo, but does the threaded end of the spring touch the mount on top? If so, that's at least a major part of your problem. You should have a little plastic grommet that looks kind of like two stacked washers, one slightly smaller than the other, with a 3/8" hole in the center. That grommet fits in the mount, then the spring threads fit through the hole. that keeps the antenna (the threads and everything above it) from contacting the vehicle.
x2
I'm an antenna noob and even have a no-ground antenna cable from firestik that supposedly doesn't care whether the mount is grounded or not. I still spike the SWR meter readings on mine though and am not sure why
However, you should have at least one and sometimes 2 nylon insulator washers (technical term I "borrowed" from Firestiks webpage ) so the antenna itself doesn't ground out (IIRC).
Here are some "borrowed" pics as well showing the insulator washers. My setup looks like the left most mount. I think yours resembles the mount on the far right which looks like it only requires 1 insulator.
Old 06-11-2007, 12:02 AM
Originally Posted by red cruiser View Post
I used the very small & thin nylon washer provided, nothing resembling a grommet like you describe. I'm sure I can find one, drill my mounting hole bigger to accomodate it and all should be well. Nothing like that needed on the bottom?
So what's that extra wire on the antenna for?
No clue about the extra wire (I'm using a Firestik) but I might have an extra nylon insulator washer floating around if you have trouble finding one.
Old 06-11-2007, 12:16 AM
ScaldedDog's Avatar
It's all clear to me now - doh!
The threaded end of the spring probably does touch the mount on top, I used the very small & thin nylon washer provided, nothing resembling a grommet like you describe. I'm sure I can find one, drill my mounting hole bigger to accomodate it and all should be well. Nothing like that needed on the bottom?
Thanks, I appreciate it!
Having this conversation is funny to me, as I remember having the exact set of questions and issues you're having.
Jeff's pics are great, and you'll need one of those plastic grommets on top, and none on the bottom. The shielding of the antenna wire should be grounded at the antenna base, and it connects to the outside screw mount at the end of the cable. When it touches the mount, like yours does, grounding is accomplished. (NOTE: I'm assuming your spare tire carrier is grounded. If not, you'll continue to have problems.) The center wire of the cable should *not* be grounded, and that's why you need the grommet.
The extra wire on the Wilson Silverload antennas is used to shift the impedance (IIRC, the chances of which are not good) to get a better SWR *in some situations*. The general idea is to tune it as good as you can without the wire. If your SWR's are poor (>2.0 but less than infinity) after you're sure you've got everything right, then you can ground the extra wire. If it helps, great. If not, disconnect it and tape it to the antenna. (I've tuned two of these, and it didn't help either time. YMMV.)
BTW, did you roll your own connector on the end of the wire? If so, test the wire to make sure the center doesn't have continuity with the shielding. It' very easy to let a copper strand from the braided shield touch the center pin.
Mark
http://www.scaldeddog.com
Old 06-11-2007, 12:48 AM
Chris's Avatar
Chris Chris is offline
x2
Thanks for the pics, I'll pick one up tomorrow.
Old 06-11-2007, 12:53 AM
Chris's Avatar
Mark
Nope, bought the wire complete with ends, I know enough not to go there.
Just when I think I'm understanding this you throw in "shift the impedance"
By this time tomorrow I'll know whether or not I need to ground the bumper or go back to my little magnetic antenna.
Old 06-11-2007, 03:19 PM
Chris's Avatar
Thanks Mark for your guidance and Jeff for the pics. Got what I needed at Ace and everything's good. The swing arm hinge isn't a great ground but the latch is fine. Get readings from 1 on the low channels creeping towards 2 on the highest. The adjustment on the end doesn't help at all so it's all good now, readings I can certainly live with.
Once again, asking a few questions save hours of frustration!
Old 06-11-2007, 04:42 PM
Good deal! Wish mine was working as well as yours
Someday I'll get it working right
Old 06-11-2007, 05:29 PM
Chris's Avatar
I wish I could help you but it sounds like an impedence issue.
That was it in my case, my ignorance was impeding me.
Old 06-11-2007, 11:35 PM
ScaldedDog's Avatar
So *that's* what that extra wire is for!!!
Glad it worked out.
Mark
Old 06-12-2007, 04:12 PM
Chris-
To get any good reception out of the setup on the swing out, you will need to add a grounding strap... not just a wire. Honestly, I am not absolutley sure why but in my search from guys in the know it, it is what you have to do to get a proper ground.
It is the big fat flat ground strap found on some cars between the engine and the frame. Most NAPA's carry them.
Then once you have one. You mount it to the swing out carrier right beside the hinge and attach the other end to your cruiser, maybe through the bumper bolts or something similar.
It isn't hard just a bit of work.
Hope it helps.
Drew
