Old 07-31-2007, 09:22 PM
that mantra only applies to Land Rovers
Uh oh...mine appears to be coming from the passenger side...of course I am having trouble crawling under there with the prospect of having all that junk fall on my face, so I don't know for sure. Hopefully it's something simple like the speedo cable or something.
Old 08-01-2007, 10:20 AM
Matt, pulling all the seats, heater, tuffy, ect. Isn't really that bad. Sure you'll see some stuff you don't wan't to but you can deal with that another time. Getting the stick out is pretty easy once you've done it. I use a needle nose vice grip. Open it a little wider that the diameter of the stick. Press down springloaded deal and turn it 90 degrees. Stick will come right out.
My philosophy is "tring to save time by not taking thing apart always takes longer than if I had just pulled it all apart to begin with."
Old 08-01-2007, 10:26 AM
I don't think cardinals was leaking from the top of the case when I crawled under it
Old 08-01-2007, 10:46 AM
CardinalFJ60's Avatar
Default just another place it was leakin'...
You're right Wes - it's leaking from where you pointed out. I also discovered the drip from the top of the case above/left of the fill plug as you're looking at it. It's dripping down the little contour. (sigh) The good news is that I only had to add like 1/2 quart to the x-fer after 3-4 months of leaking.
