Old 06-20-2007, 08:58 AM
Great.
Which one of these is "4Runner Flares"?
I emailed him...
KDØRCH
Old 06-20-2007, 03:28 PM
RockRunner's Avatar
Bill, I am running the 1.5" spacers up front with 2" BS on the rims. It tracks very nice and am able to run 8" rims with the same overal width as I would if I was running 15x10 with 3.75 BS. You are more than welcome to come over and try a wheel or two to see how it looks and or works.
Thanks T aka Tom KR0MPS
TLCA #6136
Old 06-21-2007, 10:41 AM
Thanks, Tom! Hey, you're running steelies though, right?
I feel like a bit of a moron- you guys were trying to tell me 2" BS is not available in alloy. The Champion beadlocks are all 3.75, she said I could send her any alloy wheel and they would beadlock 'em, but 3" BS is all I can find, and the cost for 3/4" seems hardly worth it. I considered the Stauns, and functionally they make a WHOLE lot of sense, but I like the idea of function + bling (don't be givin' me no grief here...), and since I tend to tear up wheels on the rocks, a replaceable ring protects the valve and can be renewed if needed... Could use small adapters (spacers) in the rear, and larger ones in the front. Haven't had issues with adapters.
I guess another thought is going with 15x10s. 3.75 on a 10 nets a bit more width, and if I am correct, results in a bit more road stability due to the sidewall, no? Running 8s now. Drawback being, running low pressure puts the rim right against rocks on any side load. No?
KDØRCH
Old 06-21-2007, 04:38 PM
RockRunner's Avatar
I am running steelies with the valve stems moved to the middle.
I looked into the Stauns and may go with those, they work great from what I have read and seen.
My deal with going with the 2" BS is that the inside of the tires do not rub at all on the truck. I could maybe go up to 15" wide tires and still have no problem rubbing the inner fender well.
Not sure about the low pressure and 8" rims, the wider the rim the straighter the sidewall, so with 8" rims you have more of a bulge that protects the rim but leaves the sidewall exposed.
Just go fo rthe in between rims, 15x9 with 2.5" BS I believe Walker Evans makes them, may be 16 or 17' rims..............very pricey and very bling!!
TLCA #6136
Old 06-22-2007, 12:05 AM
I'm guessing Champion beadlocks are 15x9... seeing as how they start life as 15x8? The thought just occurred to me.
KDØRCH
Old 06-22-2007, 08:36 AM
Beadlocks are different as yes technically when they are created the bead moves out 1/2 - 3/4" but the width will vary depending on tire used. For instance a set of TSL/Bogger/SX's will stick out nearly 1.5" further so that would make the wheel a 10.5 wide.
KØUBN
Old 06-25-2007, 09:29 PM
Cheese Cheese is offline
Send a message via AIM to Cheese
Glass and flares? Let it ride.
I have never seen an AL wheel with 2" BS.
My OMF beadlocks started out as 15x7's and are just over 8 with a lock. I have Diamonds so no spacers up front.
Not sure how much good going to a 9" wheel is going to be by the seat of the pants from the driver's seat if you keep the same BS.
Assist without spacers makes a really nice steering front end.
Adrian Flygt
Sold 4Runner, thanks meth heads.
"There's a feeling I get when I look to the west and my spirit is longing for leaving..."
www.sleeoffroad.com
www.sonoransteel.com
