Old 11-14-2005, 11:35 AM
Maddmatt Maddmatt is offline
Originally Posted by Hulk
If they know what they are doing, the emissions tester guys WILL look for the airrail and smog pump. Matt, you got lucky.
My 40 fails every year. The tags expired in September -- I'm waiting until January so that it will be 25 years old and I can get the 5-year plates (it's a 1981 model).
TJ, they shouldn't have put you on the rollers. Vehicles from 1981 and older require tail pipe emission tests only.
I don't know, I thought '76 was old enough for tail pipe test only. Anyway, I had it in there twice, and the fact that my entire exhaust system consists of an old SOR header and a muffler never came up. Maybe just take it where I took it. It's the emissions test place on airport road in Boulder. They seem to put a lot of time into testing the gas tank cap, maybe that's all that they covered in their training. Anyway, now I've got the 5 year plates, so I don't plan to worry about it again until 2009
I did see the lady nearly put an old full size dodge through the wall last week when I was getting my wife's suby tested. Very big probably early '80s Dodge with a plow hitch and some tall skinny muds on it, with a very straight and clean body that the guy had obviously put some time into. She was trying to drive it off the rollers, and had the back end bouncing from side to side pretty wildly. I wanted to talk to the guy about his truck, but he went running out of the waiting room with this horrified look on his face.
Anyway, back on topic. To me a potentially failed test is worth it, you'll either pass or know exactly what you need to pass.
-Matt
Matt
1996 4Runner
Old 11-14-2005, 01:05 PM
76 only needs tail pipe test.
76 is eligible for collector's plates. I have never seen or heard of (until Ken's post) anything but the 5 year variety. Unless they change the laws, once you get the collector plates you never have to be tested again, only exception is whenever a vehicle changes hands (or moves here from out of the AIR program area).
The only equipment you MUST have is smog pump - it must be hooked up and appear to be functioning, whether it is or not. Nothing else is required. Yes they will check for unleaded sized filler and cat, but that was not introduced until the 1979 model year, so it doesn't apply to a 76.
All the other suggestions apply: Fresh oil change, new air filter element, new plugs, set timing to factory 7 BTDC, increase idle speed some. Do not be tempted to lean out the idle mixture: that will produce "lean miss" and fail you. You should be able to get away with it under the numbers with sea level jetting, I did for decades in my 76. Good luck!
Old 11-14-2005, 01:17 PM
Thanks again everyone.
I will give it a shot after a little tuning up this week.
I appreciate all your help. I will let you know how it goes.
Drew <><
Old 11-14-2005, 02:02 PM
74fj40's Avatar
74fj40 74fj40 is offline
Hulk - My dad just registered an 81 bimmer and got 5 yr plates - don't ask me why, but they count 1981 as one of the years, so it's 25 years old this year.
2005 Silverado 2500hd Duramax
1972 Toyota FJ40
1967 Porsche 912(100% stock)
[/font]
Old 11-14-2005, 06:29 PM
Disappointing
Ige told me that this was true. I've been too lazy to call to verify this. I'll probably still wait until January, since I'm busy as heck through the end of the year.
Originally Posted by nakman
Old 06-15-2006, 09:23 AM
COMITX
Guest
Posts: n/a
Question Collector's Plates
Hi Everyone,
I'm making my return to the Denver area from Texas and would like to resurrect this old post.
Is the 5 year collector plate rule still in tact about not having to get emissions testing done after passing?
Is it still true that all I need is to have an air pump that appears to be working to get it to pass?
I'm considering a trade down here for a FJ40 and need to know the answers to these questions before I pull the trigger.
Thanks for your help and I look forward to meeting everyone once I get settled in up there.
Ken
Old 06-15-2006, 09:40 AM
IanB's Avatar
IanB IanB is offline
Yes, pass emissions once, get collectors plates, no more emmissions.
Air pump depends on who does the emissions inspection. Technically yes, all equipment must be on the truck and functional. In reality, very few emissions employees have a clue what is supposed to be under the hood of a 25-30 year old vehicle.
Also, only certain counties have emissions, its not state wide, so it would depend on where you end up living.
1976 FJ-40
2001 UZJ-100
Old 06-15-2006, 10:00 AM
Originally Posted by COMITX
Hi Everyone,
Ken
Hi Ken, welcome back! Yes, the 5 year collector plates are still available. Under current regulations, once you get them, you do not need to go through smog again. This can change; there have been rumblings within the legislature of doing away with emission stations and relying entirely on mobile sniffer vans which would test your tailpipe emissions as you drive by. The problem with this system is that you could now get nailed just by driving around.
In order to pass the current system, required equipment will depend on the model year of your 40. For example, if your year originally had a smog pump, you must have one and have it at least *appear* to be working to pass the visual. 1981 and older does not need to go to envirotest, you can get a non-treadmill test at an independent station if you wish. If your 40 is 1979 or newer, it will also need the cat and smaller filler neck. For technical reasons, you do NOT need EGR in Colorado, even if the rig was so equipped from the factory. Also, none of the factory smog spaghetti needs to be present. Under all circumstances, you still have to pass actual emissions, either treadmill at envirotest or independent for 1981 and older. Note that only CO and HC are tested, unlike some states where they also test for NxOx.
Good luck and happy cruisin'!
Old 06-15-2006, 01:42 PM
COMITX
Guest
Posts: n/a
Thanks Ian & Jeff,
It sounds hopeful. When I get back, I'll probably be asking about the best independent shops to go to. It sounds like Charley's in Boulder might be worth visiting. Do they test too or just stick to repairs?
Thanks again,
Ken
Old 06-15-2006, 01:48 PM
Romer Romer is offline
I went to a place on South Buckley road in Aurora in 2003. Even though I was obviously de-smogged, he didn't care and passed me as long as the computer said I was within limits.
