Old 07-29-2007, 09:47 PM
Talking You knew it was coming...cooling system
This spring (and especially today, going slow/idling on the trail) I have been experiencing a little overheating. I'm thinking it may be fan clutch related because once I get moving then the temp gauge drops way down again, but it was rising to just above the hatch close to the H (meaning just inside the "red" zone) today if I left it idling.
-Is there a service interval for the fan clutch (I'm assuming all I should need to do is change out the clutch fluid or whatever)
-Is this a drain/refill procedure or do you just add more? I'm assuming you can buy it at NAPA etc.
I'm gonna try this first, seems like a simple solution if it is the problem and it doesn't seem to me to be like a thermostat issue.
Old 07-29-2007, 10:16 PM
Matt-
I dont think the clutch has any fluid in it, I think it is mechanically operated with a thermal spring coil thingy... I could be wrong.
As for the radiator, you might try flushing it and refilling it with the proper mix. You might consider having the radiator recored, but I would see how it goes with good coolant and a good flushing.
Old 07-30-2007, 12:18 AM
Originally Posted by Rezarf View Post
Matt-
Clutch fans usually do have a viscous fluid (silicone). The bi-metal spring simply closes bi pass ports inside the clutch making the clutch more resistant to freewheeling.
Old 07-30-2007, 12:20 PM
There you go! I learn something new everyday here... sometimes twice a day.
Drew
Old 07-30-2007, 12:43 PM
A coolant flush, new thermostat and gaskets is an easy first step and good preventative measure. Try that first if it's been awhile since you did a flush. I just did this on my 40 and it's running much cooler.
(I waited too long to do this maintenance on my 60 and now I'm looking at replacing the radiator, water pump and all the hoses to the tune of 500 bones...)
Old 07-30-2007, 09:54 PM
knew it was easy, just low on coolant. I've been leaking a little bit here and there, apparently it adds up?
(that was a joke) - I had the rad hot tanked etc. summer 05, heater core I cleaned out this last spring, so should be good to go otherwise. I'm still going to look into the fan clutch a little bit, just so I know how it all works
