Old 08-24-2007, 12:14 PM
CardinalFJ60's Avatar
Default Castor angle, shims, etc.
My 40 is practically dangerous driving on the highway with how it follows the ruts, etc. It's mostly because of my castor being at like -2.5 degrees. I have 2.5 degree shims that will bring it to about 0 (zero). I beleive the spec on castor is +1 (+/- .5)...and I think (hope) this should greatly improve the wandering.
questions:
- will adding the 2.5 shims mess with the pinion angle much? (u-joint issues down the road?)
- do I need to worry about shimming the rear?
- Is castor at zero 'close enough' or should try to get to positive?
thanks!
Old 08-24-2007, 12:31 PM
Lots of good info in this thread:
http://www.risingsun4x4club.org/foru...ighlight=shims
I went through this routine before Moab this year.
Old 08-24-2007, 01:34 PM
If you're going to the trouble to put in the shims, I'd go higher that 2.5s. 4.0 is probably the next size that is easy to find non custom. You'll likely need to use extended center pins in the springs to be sure the pins make it into the spring clamp plates. You may end up with some driveline vibration but what are you doing with the front shaft spinning on the highway anyhow?
Old 08-24-2007, 03:05 PM
Default hmm...4 degree, huh?
yeah, that's what I was thinking but have the 2.5s already - I'll re-think things.
And you're right - front DS not spinning on the highway...just over thinking things...
thanks!
Old 08-25-2007, 09:28 PM
PabloCruise's Avatar
I threw 4 degree shims in my front end:
http://forum.ih8mud.com/showthread.php?t=151088
Did a front end shop measure your caster?
TJS K0TNP
1978 FJ-40
1974 FJ-55 w/ 3FE
TLCA #10713
Old 08-26-2007, 11:28 AM
Default yup..measured by shop
front end shop measured them, I have the specs at work. I wanna say -2.1 and -2.5.
I put them on this weekend...we'll see how it is. I just put in the 2.5's we'll see how it is...
-s
Old 03-30-2010, 05:55 AM
chrisbj chrisbj is offline
how did this work out? i have the same problem!
Old 03-30-2010, 10:33 AM
Maddmatt Maddmatt is offline
Sounds like a lot of work to me - I think I better come over and pick up that dangerous vehicle, and study it's habits over the summer. I'll bring it back in October. You could help me out by taking the top off before I get there
Matt
1996 4Runner
Old 03-30-2010, 10:40 AM
Default hahah...
Nice try, Matt.
The 2.5 degree shims made a big difference, but with the setup I currently have, I might have benefit more with teh 4degree. overall, I'm happy with it.
also be sure to check all the other areas for slop. I had some slop in the center arm assembly, too.
