Go Back   Rising Sun Member Forums > Toyota 4x4 > 4Wheeling and Event Staging Area
Old 10-18-2007, 01:38 PM
Default Coney Flats/Buchannon Pass trail
I planning to go drive the Coney Flats loop on Saturday with a possible hike up to Buchannon Pass. I'm not sure of the current conditions up there but it will likely close for the season soon. For those not familiar with the trail, its relatively mild with a few obstacles that just about any stock Toyota can handle. The meeting point is the parking lot in the back of the Camp Dick campround, (behind Peaceful Valley.) The trail ends at Beaver Reservoir. I haven't picked a meeting time yet something around 10ish would be good.
Old 10-19-2007, 08:27 AM
bump
Old 10-19-2007, 11:44 AM
CardinalFJ60's Avatar
Default I was there in August
I went there with a buddy in his very stock J**p cherokee laredo. He did it with a little decent driving skills. On the back side of the loop (we started near Beaver Reservoir and ended at Camp Dick) after the water crossing, there were a couple tight spots, and a little channel of H20 that was about bumper height, but nothing too crazy. It's a fun run. I have stuff going on, but will bump for a fun run.
Old 10-19-2007, 12:35 PM
shootska, wish I could go! Sounds fun, will have to try next summer!
