  #651
Old 04-21-2010, 01:20 PM
treerootCO's Avatar
http://forum.ih8mud.com/80-series-te...ml#post5476634
Decided to move the winch solenoid to a new spot on the Short Bus bumper to make room for another Rigid Industries LED light. The spot behind the winch is exactly the right size for the solenoids with zero room to spare. The JDM aux fan is just above it but does not touch, the bumper braces are welded in just the right spots to make it work, and the frame is just far enough back for it all to fit. The bumper was drilled and tapped for bolts.
www.root45.com
www.risingsun4x4club.org
TLCA #14133
  #652
Old 04-23-2010, 04:01 PM
I used a defroster button out of a 4runner for the wince enable. I ran the ground through it so that the winch in and winch out controls are only active when the enable button is active. It also has a light so I know it is on. The 4 runner switches are the right style but you will need to source some clear plastic because the lables are a sandwich of things and can't be sanded clear.
The stock button labels are clear plastic that is silk screened from the back. All of them have a green overlay and some of them also have a black mask. That was sanded off with 1200 grit sandpaper and followed up with plastic polish. The labels are from http://forum.ih8mud.com/80-series-te...gle-sheet.html - NLXTACY just cleaned up a bit. That gets printed on some card stock and superglue makes the paper translucent. I used a green silk screen paint to keep the OE color even though I use blue LEDs behind it. Without the green the color is more blue. I like the teal color and it keeps everything matching. The last step was to use vinyl to keep light showing through the paper so that was applied in reverse to the buttons. Here are the images used. The bigger one is the mask that is behind it.
Mike, you are the king of the details.
  #653
Old 04-23-2010, 04:22 PM
lets see the light bar on !
WØREK
  #654
Old 05-14-2010, 07:55 PM
treerootCO's Avatar
Soon, very soon.
The interior winch controls are in but there is a ghost in the machine. It likes to spool out every now and then. I think the Warn 9.5XP is different that earlier designs as the colors have changed. Had to make black white, white red, and red black for it to work. The disable switch keeps it in check until I can figure out where the stray voltage is coming from.
Here is the WARN 9.5XP wiring diagram, post #3
www.root45.com
TLCA #14133
  #655
Old 05-15-2010, 09:59 AM
sleeoffroad's Avatar
Mike, I have the color changes documented at the shop. Call me on Monday.
Christo Slee
KØSLE
www.sleeoffroad.com
  #656
Old 05-15-2010, 07:43 PM
you need to pop that engine out and install this...
http://www.titanmotorsports.com/to1fzenpr1hp.html
WØREK
  #657
Old 05-15-2010, 08:10 PM
I agree! Then he can have all the street racer bling bling he wants and no one will give him any lip!
KØUBN
Colorado Trail Patrol
Stay on the Trail!
  #658
Old 05-15-2010, 10:56 PM
That's a STEAL at only $45 per HP
  #659
Old 05-16-2010, 06:47 AM
The rig is looking sweet man....
Super sweet...
KDØGWX
  #660
Old 05-23-2010, 02:44 PM
treerootCO's Avatar
So that is what 200,000 spark plugs look like
They must have have 2mm gap after the wear.
Changed out the plugs, wires, cap, rotor, PCV, belts, etc.
I thought that side sounded funny...
www.root45.com
TLCA #14133
