  #671
Old 06-21-2010, 01:53 PM
Cool. I think I'll do that too now
KDØGWX
  #672
Old 06-21-2010, 02:21 PM
treerootCO's Avatar
Event Coordinator
Originally Posted by Snowrun View Post
How well did it work? Is it all fresh and clean smelling now?
Bring the truck by and we can fix you up in the parking lot. All I need you to bring is a 1/4 bit and cordless drill. It worked better than I would have thought. A/C is fresh and cool!
www.root45.com
www.risingsun4x4club.org
TLCA #14133
  #673
Old 06-21-2010, 10:37 PM
Snowrun's Avatar
Snowrun Snowrun is offline
Thank you for helping with that. It made a big difference. Now if I can just clean the spilled 90 weight up it might be tolerable to ride in.
'94 FZJ-80 Locked
'99 LX 470
TLCA#21035
My Cruiser videos on Youtube
  #674
Old 06-22-2010, 05:04 PM
PabloCruise's Avatar
Found the terminal blocks cheaper at Delcity.
http://www.delcity.net/store/Stud-Ty...ck/p_71704.a_1
Attachment 16707
I would think you would want that positive one covered/protected so you don't inadvertantly commit to some under-hood welding.
Not saying you would, but I know my own behaviors...
TJS K0TNP
1978 FJ-40
1974 FJ-55 w/ 3FE
TLCA #10713
  #675
Old 07-23-2010, 05:07 PM
treerootCO's Avatar
Event Coordinator
Swapped in a '94 radiator and modded the blue fan clutch with 25ml of 10,000cst silicone. The 80 was running in the 200s whenever it got hotter than 90 outside. After the changes, the temp went to 191 once. The rest of the time it was around 175-190. The other change made was to replace all the foam between the radiator and the radiator support. I also added foam between the radiator and the fan shroud. The thought is to direct as much air through the radiator as possible.
Also sourced an all metal, American made, shovel.
http://rayssupplycompany.com/index.p...ort=20a&page=2
King of Spades DHV Series:
The D grip handled shovels are available in a pointed edge round blade and a pointed edge flat blade. All metal construction. D grip handled shovel with 12” blade.
www.root45.com
TLCA #14133
  #676
Old 07-28-2010, 03:29 AM
treerootCO's Avatar
Event Coordinator
Ok, so my HIDs are obnoxious. Working on a projector retrofit to make it go fix
Before:
Low beam 35watt HID
f4 - 1/2sec - 100iso
High beam 50watt HID
50" RigidLED + 35lowHID + 55highHID
www.root45.com
TLCA #14133
  #677
Old 08-23-2010, 02:31 PM
treerootCO's Avatar
Event Coordinator
No more blinding HIDs
Added the FXR projectors to the Depo lights...
www.root45.com
TLCA #14133
  #678
Old 08-25-2010, 03:04 PM
treerootCO's Avatar
Event Coordinator
http://forum.ih8mud.com/80-series-te...rojectors.html
www.root45.com
TLCA #14133
  #679
Old 08-25-2010, 03:31 PM
Cool. What did you have to do to fit those projectors in the housing?
Nice cutoff!
  #680
Old 09-20-2010, 02:42 AM
treerootCO's Avatar
Event Coordinator
Nice cutoff!
The pics of the modifications are mostly here: http://forum.ih8mud.com/80-series-te...rojectors.html
Ok, I may have gone overboard on this one. I think I found the limit of brightness when measured on a scale of comfort.
I added double the LEDs to the two stock dome lights and the additional one in the cargo area. The two 48 SMT boards are just super glued together and the wires of one soldered to the other.
When compared to the lighting on the house, you can see just how bright the light is in the 80.
There is an extra courtesy light in the front door. Other than that, the only change was to add the LEDs. Keep in mind, you are looking through tinted glass in the rear windows. The cargo area is stupid bright now.
www.root45.com
TLCA #14133
