  #681
Old 09-20-2010, 11:04 AM
The cargo area is stupid bright now.
If anyone needs emergency surgery on the trail, they can use your 80 as an operating room.
Originally Posted by nakman
  #682
Old 09-20-2010, 12:07 PM
just beautiful, Mike.
  #683
Old 09-20-2010, 03:08 PM
Inukshuk's Avatar
Inukshuk Inukshuk is offline
From my house it looked like the Mile Hi Stadium lights were on.
Is that "48 LED SMT Array" a plug in bulb? Better interior LED lighting would be a huge plus for me and those seemed to be selling for a very reasonable $24.99.
  #684
Old 09-20-2010, 06:08 PM
treerootCO's Avatar
Event Coordinator
It comes with the 31mm festoon. I popped 4 of them before I realized the new version isn't protected from reverse polarity. Silly diode.... Just make sure you match the red wire side with the positive.
www.root45.com
www.risingsun4x4club.org
TLCA #14133
  #685
Old 09-26-2010, 01:21 PM
Snowrun's Avatar
Snowrun Snowrun is online now
This is the low pressure power steering hose that let go on the trail. I ordered part number 44412-28160 from Toyota, approximately $25. The Cruiser part is discontinued but the Previa is a close match and rated for ATF. The web also says the line is 10mm not 3/8" but I don't know if that makes any difference.
Attachment 16448
This is the hole that caused the issues....
Attachment 16449
Thanks for posting the part number seeing as I have now had the exact same failure in the exact same spot on the hose.
I think this might be something others should put on their 80 series PM list.
'94 FZJ-80 Locked
'99 LX 470
TLCA#21035
My Cruiser videos on Youtube
  #686
Old 12-28-2010, 07:59 PM
treerootCO's Avatar
Event Coordinator
Re-welded the upper pan-hard rod mount. The hole had egged itself out and was starting to make awful clunking noises.
www.root45.com
TLCA #14133
  #687
Old 12-28-2010, 10:51 PM
coax's Avatar
coax coax is offline
What kind of welder did you use to do the work? I've got a low-speed cluck that I am pretty sure is the rear panhard. Hoping its just the bushing and no welding necessary, but I really don't feel like digging into it while its cold out. Nice job!
-Corey
'74 project pig (sold)
  #688
Old 12-29-2010, 08:12 AM
treerootCO's Avatar
Event Coordinator
It is a Miller 175, 220volt, wire feed mig. Must have left the tank on because the shielding gas was all gone. That always makes overhead welding fun with solid wire. I was able to get the drill in from the back to redrill the holes. You couldn't tell by looking at the hole either but the bolt had about an 1/8 inch play in all directions front and back.
www.root45.com
TLCA #14133
  #689
Old 12-29-2010, 03:29 PM
I also get some god awful noises from below. Maybe it's time to buy a new bolt, cut off the old one and take a look
  #690
Old 12-30-2010, 11:45 AM
Inukshuk's Avatar
Could this be the source of a low-temperature clunk I get?
