Go Back   Rising Sun Member Forums > Toyota 4x4 > 4Wheeling and Event Staging Area
Old 12-07-2007, 08:18 AM
JadeRunner's Avatar
Cruise Moab Co-Chairman
Default 2008 Snow and Pizza Run - Yankee Hill
Meeting Place: Cemetery area half mile above (west) of Central City-the normal spot. Pizza at Beau Jo's Pizza after the run.
Date: Saturday Jan. 5th, 2008
Time: Meet at 9am or earlier and leave soon after 9:30am
CB Channel 4
Will will air down and chain up (if your using chains) at the meeting place.
Be prepared to be trudging through lots and lots of snow, especially when you exit your stuck rig to hook up a strap. Gater's, snow suits, gortex or whatever - just be prepared to stay warm and dry. It can be really cold and windy. Make sure you have at least one strap and tow points available front and rear.
We will meet at Beau Jo's in Idaho Springs for Pizza after the run. Around 4-5 pm. The club will buy pizza and pop.
Scott Yoder KD0DHP
Old 12-07-2007, 08:22 AM
I love that picture! The weather today has me so stoked up for vehicular entertainment! Let it snow....let it snow....let it snow!
Old 12-07-2007, 08:28 AM
I would like to make this run, but all I have for a recovery point on the back of my 40 is a tow ball... Anyone have a recommendation for something that can be added to replace that without having to modify the crossmember?
Old 12-07-2007, 08:35 AM
Old 12-07-2007, 09:05 AM
That would be ideal. Do you have one that fits the bolt pattern on a 40?
Old 12-07-2007, 09:16 AM
bskey's Avatar
bskey bskey is offline
I should be able to make this! Now a good reason to get those chains!
Brett
'85 SR5 Rustbucket........ a work in progress. I always have something to do!!
Old 12-07-2007, 09:26 AM
Actually, I carry one of these so I can yank the unprepared out of my way!
I would think you could figure a way to off set the holes in the hitch to fit the Cruiser pattern. Then again it's just an FJ-40 and considering the fact that tow points are more important than a lift or other accessories it seems that maybe a hole or two could be drilled if necessary so proper safety equipment could be installed!
Old 12-07-2007, 09:36 AM
Looks like $OR sells one that should work.
I, of course, only need it to pull others out of snowdrifts.
Old 12-07-2007, 09:42 AM
Uh huh....
Old 12-07-2007, 10:12 AM
Just take the ball off and put a shackle through the bolt hole - if it'll fit.
