Old 12-10-2005, 07:13 PM
Default What else do I need...
To change out my oil pan? New gasket? From dealer? Anything else to check? Don't want to make this a big project, just want to stop THAT particular leak! Maybe I'll look into my t-case leak while I'm laying under there, maybe take the parking brake off and see what's going on. Any thoughts?
Hopefully it'll warm up long enough for me to not freeze my butt off out there...
Old 12-10-2005, 07:39 PM
Just be forewarned it may not stop it. The oil pan and cork gaskets are a PITA. instead of the cork you might to with the FIPG.
Wes
Old 12-10-2005, 08:14 PM
bh4rnnr's Avatar
bh4rnnr bh4rnnr is offline
Wes
Fipg works good. It's what is used on the Lexus oil pans. Just might want to have some glove Handy when laying the bead/installing. ONce it's on your hands, it will not leave . Some kind of Scraper is handy to remove the pan, sometimes the pan likes to not come off.... Good luck
4th gen Coloradoan.
Old 12-10-2005, 08:55 PM
Are you changing pans? or just the gasket? plan on using a scraper on the engine, wire wheel on the pan if you're using it again.. ok just read your post again, yes get a new gasket from Toyota, the one-piece deal where the hoops are attached to the sides.
Old 12-10-2005, 09:00 PM
I just don't want to be special and have the dimple under my drain plug gasket anymore . What's FIPG?
Old 12-10-2005, 09:26 PM
bh4rnnr's Avatar
I would tell you but can not remember. And to think, I use it at least once a week at work
4th gen Coloradoan.
Old 12-11-2005, 09:56 AM
FIPG - formed in place gasket - ie goo. Silicone sealant can work but can also cause problems if you over do it. You don't want any blobs to squeeze out of the joint and fall into the sump. Personally, I'd go with the OE cork gasket. The FSM for the 2F rec's a bit of goo in the corners where the bearing cap meets the pan. Make sure the sealing surface on the block is clean and the surface on the pan is both clean and flat. Its pretty easy to distort the pan from over tightening the bolts. A soft mallet and a straight edge can flatten the surface easily.
Also - some newer pans are designed to use goo or a molded rubber gasket rather than cork. Cork seems kind of primitve, but it can work quite well.
Old 12-11-2005, 10:48 AM
powderpig's Avatar
3M weather strip adheasive works great to hold the gasket to the new pan. I would not use Fipg on the pan to cork surface it is too slippery and will allow the gasket not to align properly. You will need a hand with the 3M or be good with the process so the cork aligns up properly. I then only use FIPG or similar in the corners of the cork where the block meets the arch.
In removing the pan, if it has been on a long time a propane torch works great to heat the pan and release the cork. I do not know if just using FIPG or slimilar is a great idea in place of the cork. Also when bolting the pan up, do not over tighten the bolts. It is best to stick to the torque setting or be gentle until you heat up the pan after the oil is installed and the engine is warm. the go again adn tighten the bolts and do not squish the gasket (can cut it by tighting it too much). good luck younster. later robbie
Old 12-11-2005, 11:03 AM
good luck younster.
Bwahahahaha!!! (homer voice) that's funny cause it's true..
Old 12-11-2005, 11:58 AM
Can't believe you guys diss FIPG that easily. On my 3B for the bj70 toyota doesn't even list a cork gasket any more. It's all FIPG. I *could* use a bj42 3b gasket but it goes to show if toyota is fine with it I cerntainly would too. Most of the 3B guys all use FIPG now. I replaced my F cork gasket a couple weeks ago and Like robbie said the corners are a PITA and need sealant. I can't tell if mine is still leaking or not from the pan as it's probably leaking from the side cover. In my experience if I had to do it ovr again I'd use FIPG vs the cork esp on a pan or side cover where they warp of distort easily.
