Old 12-11-2007, 10:34 PM
Speedracer Speedracer is offline
Default T-Case going south??
My transfer case sounded terrible today. When in 4 wheel drive and coasting it sounds like I've got gravel in the T-Case. When I'm accelerating it sounds fine. Shifts in and out of 4wheel drive just fine. Just sounds terrible when off the power and coasting. Any suggestions? Or do I just need to tear into and see whats wrong? Its a 78 FJ40, 4 speed trans, stock transfer case, 35" tires, Detriot Locker in the front, Aussie Locker in the Rear.
Old 12-12-2007, 07:59 AM
Sounds like mine...hopefully someone knows what it is. Does it do it in 2hi when the hubs are locked or just 4hi?
Old 12-12-2007, 09:38 AM
bearings
Old 12-12-2007, 10:40 PM
mine is doing the same thing. I am going to take it apart soon.
really frustrating since i just took it apart and put all new bearings in it.
is your silent in 2wd?
Old 12-12-2007, 11:18 PM
Mine sounds like that too, remember you are adding a few more gears to the mix. Mine likes to rumble a little.
Drew
Old 12-13-2007, 08:47 AM
I would double check the u joints or the pinion bearing. If those are loose it will sound bad in 4wd. front output nose cone bearing too.
Old 12-13-2007, 09:01 AM
Put isn't all that stuff spinning anyway when your hubs are locked?
Mine only does it when the shifter is engaged in 4hi...but not in 2hi with the hubs locked.
Old 12-13-2007, 10:12 AM
I know my pinion bearing needs work for sure... like lots of work.
Drew
Old 12-13-2007, 11:06 AM
Mine also does it in 2hi with the hubs locked. When running down the highway in 2wd with the hubs unlocked the whole drive trains sounds fine. Very little vibration in either the tranny shifter or the t-case shifter. All American 4wheel drive is here by my office so I'm taking it by there this afternoon to let them listen to it. They put new gears and bearings in my rear 3rd member over the summer and did an excellent job so I trust them. Might also take it to another shop in Castle Rock for a 2nd opinion.
Old 12-13-2007, 11:11 AM
Wes, your reply just jogged my memory. When I was running circle track in Kansas City I had the pinion nut loosen up on me one night. It exhibited the same noise as what I'm hearing now. Fine when under power, but when you let off the gas sounds like gravel in the gears. I'll have to check that.
