Old 12-19-2007, 02:57 PM
For a bloody TRANSFER CASE FOR CRYING OUT LOUD??!
Are cruiser tcases really that much more complex than a minitruck case?
If so, ..... yech!
Nope....just stouter. 1100 is nuts as you can get a new case for close to that!
Colorado Trail Patrol
Stay on the Trail!
Old 12-19-2007, 05:07 PM
Add a handful more C-notes and you are in the custom orion and marlin toy box range!
Old 12-27-2007, 12:54 PM
Mine only does it when the shifter is engaged in 4hi...but not in 2hi with the hubs locked.
Same here, lots of noise when coasting in 4 hi. I also noticed that it sounds worse lately and my front pinion is leaking a little... Am I doing any irreparable harm by driving it this way?? I don't have the time or funds to tear into it right now. Sounds like a good spring project though, new 4 speed and TC.
  #24
Old 12-27-2007, 01:14 PM
treerootCO's Avatar
225 for parts - not OE but aftermarket
http://www.sor.com/sor/cat070.tam?xa...x=cat070%2Etam
www.root45.com
www.risingsun4x4club.org
TLCA #14133
  #25
Old 12-27-2007, 01:18 PM
Hmmmm I think I did hear a gear whine one day in the 80 .....only happens with the small pulley on the SC! (and from me at the pump! )
Stay on the Trail!
  #26
Old 12-27-2007, 01:36 PM
Is it the dinosaur thing? I'm still so confused...
Rising Sun Bio
  #27
Old 12-29-2007, 12:04 PM
I had CTS do my 78 tranny and t-case. I believe it was $1500 for the pair.
I droped a rear pinion due to a loose nut, sounded like gravel. Until the rear wheels locked up at 20 mph and I stopped faster than the 40 ever had before.
  #28
Old 12-30-2007, 10:34 AM
When that happened to me, I discovered a rock had knocked my drain plug off. Plugged it up, refilled with 90wt and all was well. You might want to check your fluid level just to make sure it's okay.
  #29
Old 01-01-2008, 09:32 AM
Speedracer Speedracer is offline
Well here is what was wrong with my T-Case. The guy that I bought the FJ from in Kansas City had rebuilt the T-Case prior to me buying the rig. Well apparently he didn't get the nut tightened down enough on the output shaft of the transmission because it came off and was bouncing around in the T-Case. It beat up the inside of the case pretty good and put some minor damage on a couple of gears.
The shop rebuilt the T-Case for me which included getting the kit, cleaning up the gears, machining the case so now I don't have to worry about using gaskets to set my clearances. Drove it home yesterday and the transmission and T-Case is super smooth and quiet now. That missing nut was also causing a pretty nasty clunk in the transmission when you let out the clutch.
  #30
Old 01-01-2008, 10:05 AM
Shark Bait's Avatar
Ahh, the loose nut. Usually it's behind the wheel.
'11 Tacoma, '12 GX460
