Old 01-09-2008, 03:01 PM
I'm in
Definite on the window mod, probable on the temp gauge mod just 'cuz if there is time, and maybe I'll even bring my new speakers that have been sitting in the garage for like forever now. Maybe after watching and helping I can tackle the 's 80 later
EDIT: I know we haven't discussed dates yet but Feb 9th & 10th are out for me
Old 01-09-2008, 03:02 PM
Romer Romer is online now
I probably should come. Sounds like you 80's guys need some moderation
Old 01-09-2008, 03:03 PM
I have all the OE parts for a dual battery mod I can bring over if someone was interested. I also have the wash bottle relocation kit from Christo.
Did you buy extras Mike? I plan to do the dual battery eventually but I've haven't procurred any of the parts yet. Not a priority on my list of to do's but if you have extra stuff I could buy then no reason not to get 'er done at least partway
Old 01-09-2008, 03:06 PM
You once threatened to make up temp gauge stickers....any hope?
I wonder...I have a Scanguage II. Might be possible to use it to determine the temps on the modded gauges? Although I have read that each one seems to come out just a little different. Not as fancy as the way RT on MUD figured it out though
Old 01-09-2008, 03:18 PM
isotel's Avatar
isotel isotel is offline
80 Guys, I have access to a Vinyl Cutter, What would be needed for the Temp Guage Stickers?? If someone designs something in Illustrator, i could have a bunch cut out!
Small Numbers can be hard to trim and install, but it may be better than, Hot/cold
1976 FJ40 TBI350 700R4 Dana300
Colorado Land Cruisers
CrAwLoRadO.com
Old 01-09-2008, 03:19 PM
Still trying to figure out if the temp gauge mod works on mini trucks (it would use the same values resistor values as a 91-92 FJ80, since the temp senders are the same on the 3F-E, 22R-E, 3VZ-FE).
But if you need extra tools, I have a Hakko 936 soldering station (I've got a few different sized tips good from ICs up to PL259 connectors), Goot CS-30 soldering iron with a regular 1.5mm tip, a big ol' roll of Kester '44' 63/37 in 0.025" diameter (I also have heavier gauge 60/40 and some 0.025" 62/36/2 silver solder if someone really wants it), a Panavise, a mini bench vise, bunch of electronics hand tools. Let me know if you want any of it for the assembly line. Years ago I went through soldering training at HP, but I'm worthless for anything smaller than about 1206 or 50 mil SOIC. I just let the techs downstairs do the 37 mil pitch and finer and the 0805, 0603 and 0402 junk.
Old 01-09-2008, 03:26 PM
All I was thinking of doing for stickers would be printing them onto clear sticker paper and cutting them out. Vinyl would be way better, but yes tough to cut. I will work on matching the font type and size with the rest of the dash numbers.. can someone feed me the numbers you'd like to have? you know, 160, 180, 220.. then we'll decide as a group where to stick 'em.
And I guess if anyone wants to do their recliner hinge mods on the same day, I would be willing to supervise that operation as well. All you need is your 2nd row seats, and the hinges from your third rows. I'm going to assume Crash has a drill press.
Old 01-09-2008, 03:44 PM
The temps do not have to be exact...it's only water temp! If your close then it's more than fine! 99.8% of the vehicles out there have temp gauges like ours that are basically an analog warning light! The trouble is if you get into exact placement of your temp stickers you will turn the project into an all day job then STILL have to wrestle the cluster back into the dash when your satisfied on the marks. RT has a pretty darn close approximation on the thread on Romers excellent 80 FAC!
The approximations are....
Full sweep peg to peg is 94
Pegged hot 244
Top of red is 227
Bottom of red 217
Center is approximately 189
Cold line is 160
Pegged cold 150
I have checked mine with my infrared gun and it's very close to the same numbers!
Old 01-09-2008, 03:48 PM
Crash's Avatar
Crash Crash is offline
Tim, your assumption is correct about the drill press and it is Slee Off Road approved - it was Christo's first shop press I believe! Dave, yes please come as an EE is always welcome at a soldering party and it would be a good chance to return any tools of mine you might still have.
Uncle Ben, I think this would be a good "Members Only" function. Might work as incentive for those fence sitters to join the club?
Old 01-09-2008, 03:57 PM
I know of one that has been in my truck for at least the last 2 club meetings, but no Crash to receive them. :-P
Do I have any others besides the leak down?
