Old 01-11-2008, 09:43 AM
FJBen's Avatar
FJBen FJBen is offline
Default ARRRGH! full front rebuild, 1 hub hot after small trip
Ok, just finished the whole front end rebuild, longfields, e-locker swap and after driving for about 15minutes on at 50mph for about 5. I went to check the the 4wd so I was going to lock in the hubs. Drivers side fine, but passenger side HOT. Like you couldn't hold your hand on it for more than a second. It was definitely all the heat in the hub.
WTF? I have a very long trip to make saturday in it (long story you'll soon know about) but now it's a little sketchy.
So I drove it into work this morning, only a few miles, and the hub was still freezing cold. No sounds, no pulling.
Is there some chance the hub could have been partially engaged?
Wheel bearings took a dive on that side?
HELP
TLCA#15530
96 285's OME 's ride
Old 01-11-2008, 09:44 AM
Wheel bearings too tight?
Old 01-11-2008, 09:50 AM
FJBen's Avatar
With the tire in the air, you can spin it pretty good and it will spin for a while. It's not really dragging that i can tell.
We used the same shims from before. The axle never got hot before.
TLCA#15530
Old 01-11-2008, 09:56 AM
Brake caliper hanging? Heats the hub more than you would think.
KDØRCH
Old 01-11-2008, 10:03 AM
FJBen's Avatar
It's a thought, I"m going to try a test drive here in the the few minutes and see if it's gets stupid hot again. Only thing I did was wash everything off at the carwash at 8:00pm last night...maybe that froze something????
It's just strange there was no heat this morning. I"ll test again.
TLCA#15530
Old 01-11-2008, 10:05 AM
Naw.
KDØRCH
Old 01-11-2008, 10:32 AM
brake drag is MOST likely.
You did a full-meal-deal rebuild, which means you pulled the caliper. Did a hard brake line get kinked? Did the old flexible brake line get damaged when you flipped the caliper out of the way? (or left it hangin'?)
Sometimes, you can't SEE the problem, but the hose swells up on the inside, preventing the brakes from backing off. I did it on my VW once. Hoses looked fine, but were old. Brake started dragging, as it got hotter, the fluid expanded and it dragged harder and harder until it went on 100% and the car would NOT move. Changed brake hoses and problem solved.
KD0FDS
Stephen
Old 01-11-2008, 11:11 AM
FJBen's Avatar
Ok...strange...
just drove around 15ish miles, 65mph...stop turn around...a few stops and goes and the hub is cold as can be. Maybe something just stuck last night???
TLCA#15530
Old 01-11-2008, 11:51 AM
Beater's Avatar
Beater Beater is offline
you could have also had something silly like a rock/gravel/sand in the pad/caliper hardware.
Happened to me once on a porsche.... only way I found out was the knick it left from being squeezed in there when I took it all apart. It had already fallen out.
j
Old 01-12-2008, 06:45 PM
Sig line says 1967 FJ40, which is drum front. Seeing the replies on this thread suggest disks. Which would mean FDC. So, Ben what's your front setup?
