Old 01-13-2008, 07:14 PM
timmbuck2's Avatar
Default Desmogged 2F
From my other thread:
...I've worked on 60s here and there over the years, and it never ceases to amaze me the miles of vacuum spaghetti those rigs have. I definitely would want a factory emissions manual to figure out what's safe to plug off and what is still needed. In particular, I would want to make sure the charcoal canister functions more or less properly....
Does anyone have a desmogged 2f, or have done it before? I will grab the emissions manual, and I have a 2f manual, but would be great if someone knew how much I could take off. After looking at Ige's 45 and 55 with a 2f, it looks like about everything can come off. Any experts out there want some beer and pizza?
Thanks.
Timm
* 00 LC
* 99 Saab Convertible
* 76 Piggie
* 1996 T-100 with 396k miles
has a 2008 FJC
KDěTIM
Old 01-13-2008, 07:21 PM
I'd keep the HAC, the EGR and both of the spark advance circuits complete. Actually the HAI and the dizzy vent system and vapor recovery system are worth keeping. Hmm what's left? Aw, heck you might as well leave it all there Seriously, if you put some fresh tubing in there, its pretty reliable other than the frequent air pump implosions.
Shark Bait's Avatar
Everything is gone on mine. I plugged the holes the air rail went in to. Just passed CO emissions just fine (for a '69).
Chris Hatfield, TLCA# 2768, KAěCBH
'12 GX460
Old 01-13-2008, 07:24 PM
timmbuck2's Avatar
Problem is some pieces are missing, and I have no idea what is what. (As usual.)
T
* 00 LC
* 76 Piggie
has a 2008 FJC
KDěTIM
Old 01-13-2008, 09:32 PM
Shark Bait's Avatar
Older than 1975 does not require emissions equipment. If you bag it all you won't have to worry about it. You don't have to say anything about the vintage of the engine. It's a inline 6 cylinder, like they all had. My , FWIW.
'12 GX460
Old 01-13-2008, 10:48 PM
I was thinking of bagging my smog stuff, but now that my smog pump is gone and my air rail is plugged, I think I'm okay with the residual "smog" tubing - I do know some of it has a purpose. There's lots of good reading on MUD though; be prepared to spend a few hours.
Old 01-14-2008, 08:53 AM
timmbuck2's Avatar
Yeah, spent a couple hours on that last night. No closer to understanding what I need to do.
T
* 00 LC
* 76 Piggie
has a 2008 FJC
KDěTIM
Old 01-14-2008, 02:34 PM
My 2F is desmogged like Chris'. Plugged air rail and everything except the charcoal canister removed.
If you can find a non-usa 2bbl carb and the vacuum advance distributor, it will be much easier to desmog. SOR sells them both but they are sort of pricey. Worth the $$ in my opinion. This is the setup I'm running along with a 6 into 1 header and MSD ignition. It passes smog no problem.
Your welcome to take a look at it any time.
Old 01-14-2008, 06:49 PM
The EGR serves no useful purpose at our elevation, and reduces performance, fuel economy and increases under-hood temperatures. I would definitely ditch it. Agree with HAC. My main advice to Timm when I was poking around that engine and rig last Saturday was to make sure that a charcoal canister can be employed. He doesn't have one, but has the later model fuel tank which is intended to be used with one.
If I had the factory emissions manual I am sure I could figure it out. I also know that Jim Chenoweth knows exactly the proper trick for "properly" desmogging a 60. Ironically, it does include recurving the centrifugal advance of the distributor to compensate for removing the EGR.
Old 01-14-2008, 06:53 PM
The FJ60 setup Timm's using already has a vacuum advance distributor. Dual vacuum advance in fact. The second advance is for the HAC.
The carb is dirty but appears perfectly serviceable. I wouldn't pop the $$$ for the non-USA version, but would instead plug off the unneeded ports and desmog using it.
