Old 01-15-2008, 12:47 PM
Tell Toyota you want a new short block...Maybe they'll insist on running some compression checks and what not first and you'll get some #'s from their tests. Who knows, maybe they'll say "You don't need a new short block, you just need to do 'X'"
Yeah, not very helpful huh...But you only got a couple months to figure out what to do and that is the best I could come up with
Old 01-15-2008, 01:28 PM
Totally. I've actually mentioned it to Jerry at Burt (he's the one who sold me the short block) in about November or December. We thought at that time that I would try working the engine harder to see if the rings set or I break a glaze. There has been no change in about 2,500 miles. It's not that my parts guy is being a pain, but that we'll have to call in the bigger guns. That I think is the part that I'm not looking forward to. I used a factory short block but bolted on an aftermarket head and cam and that I'm betting that will be fun. I also did the assembly and break-in, so they are totally gonna say I screwed it up. :-P
Old 01-15-2008, 04:57 PM
I think they'd have to show that your choice of 'other' parts caused their short block to fail. Otherwise, all short block warranties could be arbitrarily denied. A good relationship with the parts guy is critical in 'gray area' cases like this.
Old 01-15-2008, 05:21 PM
Who's the 22re expert in the area? I'd pay them to double check timing, compression, valves etc. and give you their
Old 01-16-2008, 09:29 AM
rover67 rover67 is online now
man, do a leakdown test.... that'll tell you what's happening. it is easy to do (need a compressed air source) and will really make it easy to tell what's going on. I could go by wherever you are to help if you wanted. Then you'll know... exhaust valves, intake valves, rings, head gasket, ect.
also, i don't know what cam you have, but if it is pretty agressive the motor will have less compression on a compression test... Did the cam come with a card that told you where to degree it at?
do a leakdown on it.... seriously.. before you start to tear into it. it'll tell a lot.
