Old 01-16-2008, 10:34 PM
Default computer tech
installed a new writeable dvd drive in place of a busted one (e. when unhooking it, i also unhooked the other drive (d. now, my computer doesn't show either drive existing. how can i get the computer to search for them?
edit, i did try add hardware, but computer still didn't find them
Old 01-16-2008, 10:38 PM
Romer Romer is offline
So how did you hook it up.
I will guess that you hooked this up via an IDE cable. Thats the ribbon cable that comes from the motherboard.
The IDE port the cable is tied to will have an option for a Master and Slave on the same Cable. If you have both set as master or both set as slave, neither will show up.
On some computers you have to go to BIOS settings (press delete when booting) to set up an IDE drive, some you do not.
Could also be a driver issue. Your running windows XP, did the box say XP compatible?
Old 01-16-2008, 10:44 PM
i am running xp. when i got it at microcenters, i told the salesman that. he said this would plug right in and that all the settings should be correct.
it is connected by the ribbon cable. there were two originally, i unhooked one and removed one. installed new one in place of removed one, plugged both in and hooked computer back up.
Old 01-16-2008, 10:50 PM
found both drives in device manager and properties on both show they are working properly, but my computer still doesn't show them.
Old 01-16-2008, 10:51 PM
how many things are on that one cable? If you have two items on their they both could be set as master or one cable select (C/S) and the other not. If the other drive is not your hardrive, I would disconnect it from the ribbon cable and see if thet does anything. If it recognizes it, its likely a master/slave cable issue and you need to look at the jumpers on the back of each drive.
If it doesn't recognzie it, I would go into Control Pannel and click add a device and see if it finds it, if not try and do a manual look
Also, in Control Panel, you need to get to Device Manager, might be in System . Open that up and see if there are any X or yellow marks on any devices.
Old 01-16-2008, 10:52 PM
Ok your ahead of me. Might not be the right driver though. Have you tried a google search or using the microsoft web site?
Old 01-16-2008, 10:54 PM
huh?
Old 01-16-2008, 10:56 PM
huh?
http://www.google.com/search?hl=en&q...cant+see+drive
Old 01-16-2008, 10:59 PM
Did the drive come with a driver disk or CD? Might be the driver and thats why it can't see it.
If you can't get it to work in the next few days, I'll drop up and take a look at it for you.
Past my bed time now
Old 01-16-2008, 11:01 PM
computer originally came with a dvdrom and a rewriteable. the rewriteable puked. if that's what you're asking
