Old 01-15-2016, 12:48 PM
treerootCO's Avatar
Event Coordinator
Default Question about BaoFeng GT-3 Mark II antennas
Any idea why these Diamond antennas don't work on the Baofeng radios? They transmit and receive up to about 500 yards and then nothing with the new antennas. Our test was line of sight. We swapped out the whip antennas for the stubby ones because we kept breaking the stock antennas.
aftermarket:
http://www.radioddity.com/us/diamond...tenna-5cm.html
Specification:
Model: SRH-805
Band: 144mhz/430mhz
Gain: 2.15dB
Power: 10W
Length: 4.5cm
Weight: 15G
stock
http://www.radioddity.com/us/two-way...d-antenna.html
Model: INF-641
Band: Dual Band VHF/UHF
Gain: 2.15dBi
Max.power rating: 10W
Impedance: 50 ohms
V.S.W.R: Less than 1.8
Connector: SMA-F
Type: 1/ 4wave (144/430MHz), 120/150/300/450/800MHz for receiving only
www.root45.com
www.risingsun4x4club.org
TLCA #14133
Old 01-15-2016, 01:03 PM
AimCOTaco's Avatar
Vice Commander
My first guess would be that perhaps the signal pin is not making contact with the diamonds.
FWIW I have a similar diamond (SRHF10) and I can hit Mt. Thorodin from Longmont with it on a 5W Yeasu.
Have you tried then on both bands UHF/VHF?
Andy | Longmont | TLCA#22354
Old 01-24-2016, 09:00 PM
The pin dimension on SMA is pretty precise, so Andy's suggestion is good. It's not uncommon to have the pin not make contact (for example, just one mate of a 75 ohm SMA on a 50 ohm and you ruin it because the pins are larger).
Otherwise, have you tried more than one antenna? Could just be a bad one.
