Old 01-21-2008, 12:33 PM
Default Random questions
Drum brake front axle with Selectro Hubs - will I need any special tools to disassemble this sucker? Spanner wrenches etc.?
'73 3rd member - is it 4.11?
Old 01-21-2008, 08:22 PM
First question - no.
Second question - it's fine spline, I'm pretty sure it is 4.11. Saweet.
Old 01-21-2008, 08:29 PM
fine spline pinion? or fine spline gears?
Old 01-21-2008, 09:46 PM
'73 will be fine spline side gears. Fine spline pinion 4.11's only came in early '78's and then came out again for '8-90 FJ-62's!
Old 01-21-2008, 09:49 PM
I know that... I think he thinks it's a fine spline pinion. could be if it was swapped in.
Old 01-21-2008, 10:59 PM
I figured you knew that!
Old 01-21-2008, 11:37 PM
No, I knew about the fine spline pinion...UB already learned me that one
I wasn't sure if the side gears were fine spline - it didn't make sense to me that Toyota would make the inner shaft fine spline but make the birfs coarse spline, but sure 'nuff they did. Oh well at least I got it in and it's going to work, and will give me leisure time to set up the gears in my other 3rd member. Remind me never to break a pinion again.
