  #71
Old 04-07-2008, 10:43 PM
JadeRunner's Avatar
Cruise Moab Co-Chairman
I have the tones programmed, but I can't get out unless I use simplex. Is sql.typ to be set to ENC DEC? i HAVE the FT7800.
Scott Yoder KD0DHP
  #72
Old 04-07-2008, 10:47 PM
yes
  #73
Old 04-07-2008, 10:55 PM
Disappointing
That sounds right, Scott. I just turned my radio off, but I can go back out and listen for you on 145.310. I've been sitting out in my Cruiser for the last hour, futzing with various parts. Brian had been checking in occasionally.
Originally Posted by nakman
  #74
Old 04-07-2008, 10:56 PM
JadeRunner's Avatar
Ok, i got it on the ENC mode and it's finaly working.
Thanks
Scott Yoder KD0DHP
  #75
Old 04-07-2008, 11:19 PM
Disappointing
Are you on now? I can go back out.
  #76
Old 04-14-2008, 09:25 PM
Alright you dorkisses, I'll be in the truck listening for you in a bit- try to call me on simplex if you want to test your rig installs, 146.460.
  #77
Old 04-15-2008, 01:23 AM
chirp...chirp...chirp...
, guess I need a radio first right?
On a positive note I've made my own antenna for the truck thanks to Nathaniel and I now have all of the piece parts to make my own j-pole for home use thanks to Chris for the twin lead stuff. Got the other parts at Radio Shack tonight and just have to solder it all up.
  #78
Old 04-15-2008, 05:43 AM
Groucho's Avatar
Groucho Groucho is offline
I moved to simplex with you guys, and then had a baby need, so I was away from the radio for about 10 minutes.
--Choose Wisely--
  #79
Old 04-15-2008, 08:02 AM
I tinkered with Ricecake in the garage last night and was monitoring the radio on 145.145 and 146.460 simp. Nada. Too far north and to shielded in the garage I would assume. Good thing is I have got most of my list of must do's done but still have a couple of the bigger projects to kick out.
  #80
Old 04-15-2008, 08:07 AM
Dead battery in the HT. I swear if my head wasn't screwed on, I'd forget what to do with it.
