Old 01-29-2008, 02:32 PM
Default Seat Belt Tech Thread
I'm sure a fair number of you have moved or installed different seat belts in your trucks, particular the FJ40s. I'd like to move the latch side of my seat belts from their stock location to a better spot, so I poked around under the floor. There are captured nuts in reinforced locations under the floor and tranny hump. Is it not advisable to redrill the floors? If so, what would you do to reinforce the sheet metal? I've read using washers, drilling a piece of flat stock (i.e., like a washer on steroids) and there are commercial plates. The plates look slick, you drill an oversized hole and use this plate with a captured nut, very much like stock. I wonder if you are supposed to weld it in or just sandwich the floor? Anyway, ideas, thoughts and recommendations.
Old 02-05-2008, 05:32 PM
PabloCruise's Avatar
Bump for ideas...
TJS K0TNP
1978 FJ-40
1974 FJ-55 w/ 3FE
TLCA #10713
Old 02-05-2008, 06:15 PM
Rogue Leader's Avatar
Rogue Leader Rogue Leader is offline
Here is how I did mine
TODO ES POSIBLE, NADA ES SEGUNDO
MACINNES CLAN
Well we allready got one (holy grail)
I fart in your general direction
SEAN JONES KD0DHU
Fighting fire in the last frontier.
