Old 01-30-2008, 09:40 AM
Crash's Avatar
Crash Crash is offline
Default Humor - Rover Discovery Style
Thought about putting this in Chat but it is technical related. Our 19 year old nephew, without my knowing about it, bought a used '97 Disco a couple of weeks ago. It gets worse. Yesterday, the oil light, what, no gauge?, started flickering so he stopped and checked the oil. According to him the dipstick was stained and he couldn't tell the level so he added two quarts just to be safe. Light went out for a couple of miles and then it came back on at the same time the engine died. Had it towed into town, Hays, KS, and the shop owner is telling him the engine is seized and needs to be replaced - it was overfull by two quarts. I'm driving over there tomorrow to appease my curiosity and make sure nephew isn't being given the runaround. Now the tech part, a question for the group's wisdom: What is the likely outcome of overfilling the crankcase by two quarts? Sounds as if there was an oncoming problem, the oil pressure light flickering, but is overfilling the crankcase a sure death sentence for an engine? At worst, I can tow the truck to a place that won't charge storage until nephew and parents can decide what to do and, fingers crossed, find that after cooling down, the engine starts up and the truck can be moved on its own.
Kids. And their parents that allow them to buy Discos!
Thanks for any responses no matter how derogatory.
Old 01-30-2008, 09:52 AM
treerootCO's Avatar
Too much oil you may get windage. That is about it, oil was full, oil pump wasn't working?
www.root45.com
www.risingsun4x4club.org
TLCA #14133
Old 01-30-2008, 10:19 AM
Maybe sucked oil into the intake and fouled plugs? I could see it causing it to die, but not a death sentence. That would be from other things like mentioned ^^
KDØRCH
Old 01-30-2008, 10:32 AM
Crash: I'm gunna say spun bearing = no oil pressure = light flickering = seized up.
The 2 extra qts of oil are not going to be a cause of the problem.
You know my Austin Healey background. The Rover probably leaked out any extra oil in the first 10 minutes.
Where is that story about the Girlfriend on the side of the road with the oil light on. Calls Boyfriend. Adds a quart, still not full, adds a second, still not full, adds 2 more and she tells the incredulous Boyfriend, "No I'm serious, I put in 4 quarts and it still isn't up to the top of the hole." I think she drove it home no problems.
Guy at work borrowed the boss's F350 to move something. Did him a favor in return and changed the oil. Drained the tranny, and put 2 gallons of engine oil in the engine. Engine ran fine with 2 extra gallons, but the transmission wasn't too happy about running empty after about 50 miles.
KD0FDS
Stephen
Old 01-30-2008, 10:34 AM
All is correct here! Excessive oil will cause increased windage and foaming. Results - leaks and very wet oil vapor into the intake via PCV system. It could possibly cause fouling but if it seized the problem was greater that over filled crankcase! Of course I, and everyone here, are assuming it was just two quarts over filled! If enough oil was added in thoery you could cause a hydrolock situation from oil foam or even liquid squeezing up through the rings to the combustion chamber. My guess would be a plugged or failed oiling system!
KØUBN
Colorado Trail Patrol
Stay on the Trail!
Old 01-30-2008, 10:57 AM
Crash's Avatar
I was curious about the possibility of a hydrolock situation but agree that windage and resultant oil foaming is probably the extent of being overfilled two quarts. I also agree that a bearing problem is the likely suspect if the engine is indeed seized as claimed. I'll pull the plugs and check for fouling. Do Rovers require metric or standard for most nuts and bolts? Hopefully, a '97 Rover is a little more standardized than our '90 Jaguar XJS. To pull the radiator on it required 11 different wrench sizes including metric, standard AND Whitworth or some other such size that a metric or standard wouldn't fit!!! Gawd, that was fun.
Thanks for the input ya'll.
Old 01-30-2008, 11:21 AM
What's windage? And what's a windage tray? Sorry to steal the thread...
Rising Sun Bio
Old 01-30-2008, 11:27 AM
It's oil splashing on the crank counter weights. A tray merely prevents the splashing onto the crank and other items that don't need to be oiled. It can cause significant power loss in race engines I dunno if it really affects the average rover powerloss.
WØREK
Old 01-30-2008, 11:51 AM
Yup....Wes hit close. Windage is a loss of power from the crank weights and journals traveling through an oil filled space. A "windage tray" is a baffle that prevent excess oil from the pan to splash up and a "Windage scraper" is a baffle that is close fit to the crank on the up traveling side of rotation that shears off the oil from the crank so it can return to the sump and also stops the oil from climbing the crankcase from the same rotational force. It is a power loss at high RPM and can give the engine some "free" horsepower increase by it's presence. Ultra high RPM engines (>10k) can actually cavitate the oil pump by having so much oil in suspension in the case! Cruisers have a baffle that is more for slowing the sump from dumping out when the vehicle is climbing or descending although it does have a scraper built in to control oil climb too. Unless your spinning over 5K you won't notice much effect on the dyno from scrapers and trays. So in Steve's "Rover excess oil condition" you can see what would happen if the journals/weights were actually hitting the oil surface.
KØUBN
Stay on the Trail!
Old 01-30-2008, 01:31 PM
Beater's Avatar
Beater Beater is offline
ok - so I have a rover background.
There are two oil lights on all rovers. level and pressure. VERY common amongst laymen and soccer-moms to see the oil pressure light come on, and add oil.
the 97 4.0 motor is prone to top end failure and journal failure. There is also an issue with the oil sender module on some models as well.
I would say you have a series of unfortunate events.
no whitworth, all metric. No sae.
