Old 01-31-2008, 04:38 PM
Default 80 Series Windshield Washer Squirter Tech...
Yep, all these high tech discussions about the 80 series are probably amazing the non-80 owners I'm sure
Anyway, saw this post on MUD the other day talking about an upgrade to the 80 series squirters...Pretty tragic about the guys father-in-law
Anyway, I've never been impressed by either my LX's or my 80's windshield washer squirters...I get a good "stream" but pretty crappy spread. Anyone ever upgrade their squirters to something with a better pattern? Sounds like the '01 Highlander squirters fit no problem and offer an improved spread (3 streams vs. 2).
It would be the shiz to have the even newer style squirters that throw out a real good spread (like a spray bottle spread)
It is the little things in life you know and if just the nozzles are cheap and a direct fit that is my kind of mod
Old 02-01-2008, 09:55 AM
sno bored's Avatar
sno bored sno bored is offline
Looks like someone found the part # and prices. http://forum.ih8mud.com/80-series-te...r-upgrade.html
Old 02-02-2008, 10:31 PM
My bosses suburban has sprayers built into the wipers. I always thought that would be a cool addition to a cruiser. That and Rover wipers to the headlights.
Old 07-22-2008, 09:11 AM
jjhancock's Avatar
jjhancock jjhancock is offline
I'm gonna bump this thread back up to the top as my PS squirter bit the dust last week. I figure if I'm going to have to pull the hood insulation to tackle this problem, then I may as well upgrade the nozzles themselves. Did anybody actually go ahead with the '01 Highlander squirter upgrade? Also, I hear it's a PITA to remove the hood insulation... I would assume that I should probably get some new clips for the hood insulation when I order the nozzles from CDan unless somebody knows of a trick?
Old 07-22-2008, 01:31 PM
i did it. it's ok, but not great...wider pattern, but still low pressure. i didn't remove the hood insulation, i just cut small sections out where the nozzles were. very easy to cut two small squares out.
Old 07-22-2008, 06:01 PM
Hmmm. Must have missed this thread the first time. Ige, bring your 80 to the next RS meeting so we can operate your squirters and check 'em out.
Originally Posted by nakman
