Go Back   Rising Sun Member Forums > General Tech Forum
Old 02-01-2008, 01:34 PM
Rising Sun Treasurer
Default 80 Series Alternator Tech...
Ok...the windshield squirter thread didn't generate much interest ...
So, how about this? Have any of you swapped out your stock OEM alternators for higher output ones?
When I'm running around at night with the lights on, radio on, heater/defrost going full bore, etc. and I come to a stop (idle), I notice a considerable reduction in both the fan speed/output and headlight brightness.
I'm thinking before I start adding more schtuff to my LX (aux lights, aux fuse block with other accessories, etc.) that it might be wise to upgrade to a higher output alternator. I blew my Cruiser budget in short order last year so my future mods need to be planned better
This one in particular caught my interest:
OEM bolt on alternator 170 amp
'97 LX450 - aka "The Whale"
Old 02-01-2008, 02:00 PM
I posted up there.
Looks to be worthwhile. You need to know the RPM for peak amperage. If it is delta or y-wound will make a difference, though I cannot remember which is which.
KDØRCH
Shameless commercial: use the www.SMUGMUG.com COUPON RSKbiM6oytjtw, save some dough, have a great online picture gallery - and I get some credit.
Old 02-01-2008, 02:27 PM
I posted up there.
You want delta configured windings for higher current at lower RPM and wye configuration for higher voltage at lower RPM. Nippon Denso uses a wye configuration for stock Toyota alternators AFAIK. I've always assumed this was so they charge better at idle. You need high enough potential regardless of the current to charge. A lead acid battery will charge faster and be less damaged (i.e. less sulfation) at 2.4V per cell than it will at 2.3V per cell, for example. So for the intended purpose of a stock truck it makes more sense to have it charge better in traffic and that's probably why they are configured like that. When you mod your truck, a delta can make more sense as current demands go up. But realize that even if it generates more current at low RPM, it may not have enough potential to really effectively charge the battery anyway. No solution is always ideal.
Dave
1991 RN110 Imelda the Hilux (For Sale, Make Offer)
1992 WilderNest Adventure Camper
2002 VW Jetta GL Wagon
"I am a kind of paranoid in reverse. I suspect people of plotting to make me happy."--J.D. Salinger
Old 02-01-2008, 05:10 PM
I got one of the custom alt brackets from Photoman on MUD. Discussion in thread below. However I have not installed it with the Tundra Alt yet. Nor have I heard any results from anyone else who has. Anyway OEM Tundra alt is listed at 100-130 amp I believe depending on year
http://forum.ih8mud.com/80-series-te...r-upgrade.html
1997 FZJ80, daily driver
1985 FJ60, wants me to sell it, you want it.
Old 02-01-2008, 05:33 PM
Hants's Avatar
Hants Hants is offline
I got the bracket from Photoman, too. It's a piece of art.
There's a 150A Sequoia alternator that will supposedly work with it. I've tried contact a few junkyards via carparts.com with no success yet. Next week, I'll check prices from CDan for a Toyota reman unit.
Hants 97 LX450 Slee Armor, 285 BFG/AT, OME 2.5"
KD0CXL
"Wanna race?" - Bill Morgan
Old 02-01-2008, 05:58 PM
Romer Romer is online now
Rising Sun Commander
I got lots of toys running and mine doesn't dim. Maybe you should spend that money on Dual batteries instead
You might check to make sure you have a good ground.
97 LX450 Supercharged, Locked, Lifted, Armored and some other toys
06 4Runner
2003 Z4 BMW Roadster
2005 Horizon Adventure Trailer
Old 02-01-2008, 06:47 PM
Mine in stock form sees its headlights dim when idling at a stoplight. I don't have dual batteries but my main couldn't get much bigger. maybe I've got a bad ground too.
Old 02-01-2008, 06:50 PM
Rally Committee Member
Originally Posted by Corbet View Post
Mine in stock form see its headlights dim when idling at a stoplight. I don't have dual batteries but mine main couldn't get much bigger. maybe I've got a bad ground too.
Sweet BT 31! I plan on putting one just like it in my 2nd spot....I will test it to see how long the fridge will run without recharging!
KØUBN
Matt is 2 cooool! Kevin is me!
Way North of Centennial, CO
Stay on the Trail!
'64 FJ-40 (Wildrice) - Everything works!
'97 40th Anniversary FZJ80 (Ricecake) - Everything!
Originally Posted by Beater View Post
I have a small unit.
Originally Posted by PabloCruise View Post
I think there is hope - I LOVE my 's Mamry is a great ride.
Originally Posted by DaveInDenver
OK, OK. It's true, IFS is for dinguses. :-/
Old 02-02-2008, 12:25 AM
Hmmm...I'll look into that. I only notice the dimming when the heater/defrost is going full bore. The HVAC output drop is the really noticeable thing.
Old 02-02-2008, 07:39 AM
powderpig's Avatar
One thing about rewound alternators is that they usually do not have as long of life as stock. The rest of the componetry was not designed to handle the extra amps. The brushes are not typically upgraded, nor is the voltage regulator or the diode trio(turns the ac into dc). Personally I would be more inclined to get one of the tundra alternators that are design for more amps then get a rewound alt. But if you accept that it will have shorter life, then have fun with the higher output.
Nice thing about the newer designs is the brushes can be change out rather easy and in the field with out any soldering(which is a big plus). You may want to find out where the product was rewound and see what the longivity of the product is. If there were rewound in china or mexico, it may be a iffy product. Just my thoughts as I do want to have a higher out alt, just want one that gives almost the same life as stock(200k or better).
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
