Notices
Old 02-10-2008, 06:53 PM
Default if it's not one thing....
well, roof is for the most part, done. birfs on the pig are done. but, while unloading roof supplies, the already damaged right slider on the 80 bit it....literally.
the outer tube section cracked (at the welds) on the chinaman run, apparently, it cracked below also. kind of a surprise to set my fat a** on it and have it collapse
also broken at the welds. hope this student failed welding 101.
Old 02-10-2008, 06:55 PM
Crash's Avatar
Crash Crash is offline
Not like you didn't see this one coming! Suzie would have broken it too if she had sat on it!!
Old 02-10-2008, 07:48 PM
Beater's Avatar
Beater Beater is offline
you gonna do the deed or do you want to bring it by?
Old 02-10-2008, 07:52 PM
if it was welded right, the steel would break or crack around the weld.
