Old 06-27-2012, 01:34 PM
I rebuilt a motor (toyota paseo) that had 160k and no oil changed ever in it once.
It looked pretty much like thick brown reddy whip.
It had whatever oil in it the dealer sold it with.
It had a spun rod bearing that ran until the piston hit the head and messed more stuff up.
Old 06-27-2012, 01:41 PM
Here is the report I did on the 60 a while back. This was after 4200 miles on the oil with 160k on the motor.
Old 06-27-2012, 05:29 PM
^ I like how you impressed the tech with your engine swap.
  #24
Old 06-28-2012, 11:20 AM
I've always liked the "personal" touch the Blackstone folks tend to put into their notes. Not the typical canned responses
  #25
Old 06-28-2012, 11:52 AM
I thought it was entertaining too. I wonder how big the company is or how big the section that does this stuff is.
  #26
Old 02-13-2013, 11:36 AM
Inukshuk's Avatar
Inukshuk Inukshuk is offline
just got mine. First one so the next will be telling. I asked a question and they replied, so here it is (I have not yet heard on my follow-up question:
Hi Amanda,
A super-slow coolant loss was found and resolved in two external leaks (a hose clamp and a overflow bottle cap) the level is now stable for several weeks and we highly doubt internal coolant contamination. After the rebuild I ran Valvoline Premium Conventional SAE 5W-30 for the first 1,000 miles and then switched to the Mobil 1. I do not know what oil was used in the block before my rebuild and since we did not touch the bottom end, it could be additive from prior oils.
As for the metals, my rebuilder, who specializes in Land Cruisers wrote: "I am wondering if they could of mixed this up with some one else, copper is not used in the bearings, none of the rods or mains. Even the one in the block for the oil pump is aluminum and not brass. Curious that is. I would opt to wait for the next sample to see what is up."
I did several 4x4 trips to Utah and there was plenty of dust.
-----Original Message-----
Sent: Tuesday, February 12, 2013 7:14 AM
Subject: RE: Oil Report on FZJ80-011913 (our lab number F40868)
Daniel,
Thanks for the question. It's because of the presence of sodium in your report. Sodium is a marker for antifreeze, though it can also be additive in certain oils. Mobil 1 doesn't use sodium, so if you've been using that oil for a long time, then the sodium could be coolant. If you've recently changed oils, then the sodium could be additive. Since this is just one sample, and we're not sure what was used in this engine in the past, we put a question mark in the coolant place. We should know better next time.
Sincerely,
Amanda Callahan
Blackstone Laboratories
At 06:54 AM 2/12/2013, you wrote:
>Thank you. Can you tell me why there is a question mark for antifreeze?
  #27
Old 02-13-2013, 02:16 PM
Daniel, if you are interested I could send you the reports from both the LX and the 80 as a comparison. I'm down to doing just one a year, usually in the spring so I'll have the next round of reports in a couple months. I like that you can see trends, if they exist, over time.
  #28
Old 02-13-2015, 04:15 PM
Here is mine: accidently changed the oil on the 80 without putting it in the sample bottle, so decided to use it on the 40. Will catch the 80 next time around. I had added a note that I thought I might have put ZDDP into the oil but couldn't remember, so they are confirming that it did not have ZDDP additive in it. I later found the bottle that I thought I had put in.
  #29
Old 08-01-2015, 08:54 AM
From the 80:
