Old 02-17-2008, 12:49 PM
ScaldedDog's Avatar
Default 3VZE camshaft tool needed
Hi guys. I've got one leaky camshaft seal, and thought I'd change it while I'm changing the water pump and timing belt. I can't get the bolt off, though, even with a 1/2" impact.
Does anyone have the SST, or a homemade equivalent, they'd like to rent out? I'll happily fetch and return it.
Thanks,
Mark
http://www.scaldeddog.com
Old 02-18-2008, 10:40 AM
http://risingsun4x4club.org/forum2/s...=camshaft+seal
Here is how I got it done. There are some photos of my levers in use.
KD0FDS
Stephen
Old 02-18-2008, 12:39 PM
powderpig's Avatar
Cool use of a toe and heal bar. I have used a pry bar (plastic handled one), and put it though the hole under the 12mm head of the bolt to loosen and tighten these cam pulleys on different toyota and other manifactures when replacing the seal. Good luck on what you do.
Old 02-18-2008, 02:28 PM
ScaldedDog's Avatar
That is cool. Did you use the same tool and procedure to tighten it?
Mark
