Old 02-18-2008, 05:59 PM
Keep in mind that aircraft use AM and so if you are TXing and RXing on FM, the range will seem to be very poor in both range and quality.
Still learning but I assume the ICOM was/is AM as it is made for aircraft use - thus the reason I could use it as I definitely don't have a HAM license yet
It looks like this, only much older:
The newest Icom radio is a full-size hand-held with a host of pilot-friendly functions. Features a large, rubber keypad and easy to read display for one-handed operation in the cockpit. Backlit keypad and display stays on until you turn it off—helpful for night flying. Flip-flop channel recall function stores the last 10 channels used for instant switching.
Other features:
Long life Ni-MH battery
VOR reception with CDI display
DVOR function shows the radial to or from the VOR
Duplex operation (listen on NAV, talk on COM)
200 memory channels
Dedicated 121.5 emergency key
Side tone function lets you hear your own voice as you talk
NOAA weather stations
Water resistant construction
Automatic noise limiter
Low battery alert
Receives and transmits 118.000-136.975 MHz
Receives 108.000-117.975 MHz and 161.650-163.274 MHz
5 watts PEP output
BNC antenna connector
Weighs 15.1 oz
Measures 2”w x 5”h x 1 1/2”d
Includes: belt clip, wall charger(220 Volt), antenna, rechargeable battery pack, headset adapter and carrying case.
Old 02-19-2008, 09:29 AM
Groucho's Avatar
Groucho Groucho is offline
Default Please keep it inside the bands...
Guys/Gals,
Please keep in mind that the FCC says very specifically where you can and cannot go with your privileges. If you can't get help in an emergency with the HAM equipment using your license privileges, the odds of getting someone on the Air Traffic frequencies is even less likely.
6M is 50-54 MhZ and 2M is 144-148 MhZ.
It is extremely poor form to try to operate on frequencies outside the ones granted to us as HAMs by the FCC, not to mention that doing so is illegal. Safety is the primary concern for this.
Let's perfect using our privileges first.
--Choose Wisely--
Old 02-22-2008, 06:48 PM
Not to belabor this point, but I knew I had seen a question in the book that addressed the original question (which I assume was asked for "what if" in a life and death situation). As Dave points out though actually being able to transmit may be an issue.
Test question T8B08, covered on pg 4-24
FCC 97.403, 97.405(a),(b)
Bottom line on doing anything like this, assuming it worked, is that you better make sure it is an emergency or be prepared to pay some serious consequences!
Old 02-22-2008, 10:19 PM
Groucho's Avatar
Yes,
In a genuine emergency, you may use any means at your disposal to call for help on any frequency.
Any unlicensed person may also use ANY radio in a genuine emergency. In the case of our rigs, with 2M radios in them, if your wife is the only one able to make contact with emergency services using that HAM radio while you are pinned under your cruiser, and she doesn't have a license, she may use the radio in those instances.
I am simply reminding everyone that the effort spent setting up your HAM rig to transmit using those frequencies(not to mention voiding the warranty) is not recommended. It has encouraged other licensed HAMs to use their radios illegally, and thustly jeopordizing even further the frequencies and privelages that we earned when we pass the test.
We as HAM radio operators need to remember that it is a privalege to use the frequencies that we are alloted. Every month there are other services(commercial, mostly) who try and justify their need for our frequencies over our needs. If we operate poorly, illegally and not use all of our bands, we will loose them.
I would also recommend to subscribe to QST(become an ARRL member) and just read some of the headlines. We have a fleet of folks fighting in Washington for our right to use our frequencies. QST gives articles about this, tech articles, projects(remember the best part about being a HAM is the tinkering) and other neat stuff. And don't think that it is geared only toward those guys in their basement. VHF and UHF are very popular and a substantial portion of the magazine is devoted to those bands.
Just please, please keep a responsible mindset when looking to get the most out of why you are a/becoming a HAM radio operator. If nothing else, I will thank you for it.
--Choose Wisely--
Old 02-23-2008, 10:26 AM
Bruce Miller's Avatar
Default Out of band
The QST magazine that Nathaniel mentioned, has a section every month titled FCC News. Here is one of the citations listed in the December 2007 issue. It is not where you would want your name mentioned. Makes for interesting reading. Here it is:
Guy E. Weitl, WB6HGJ, of San Diego, CA, received notification from the FCC of a complaint alleging “numerous instances of out of band operation on Twenty Meter frequencies 14.003, 14.005, 14.011 and 14.106 MHz, frequencies for which you are not authorized as a General Class licensee. The complaint also alleges that you have been sent several notices about out of band operation. The information contained in the complaint, if true, raises serious questions regarding your qualifications to retain an Amateur license.” Weitl was given 20 days to respond and was directed to “support your response with a signed and dated affidavit or declaration under penalty of perjury, verifying the truth and accuracy of the information submitted in your response.” He was warned that the FCC will use “all relevant information...including information that you disclose in your reply” to make a decision in his case, and that penalties could include “license revocation, suspension of your operator privileges, or monetary forfeiture (fine). Fines normally range from $7,500 to $10,000.
Bruce and Barbara
WØDW/ZF2KN
1966 FJ45 LWB Pickup
1985 BJ74 RHD
2006 UZJ100 with HDFT-E/H151F
2008 URJ200
