Old 02-28-2008, 03:20 PM
Thanks Drew. I still can't make up my mind on either one of those, or the one that Christo uses from Wrangler. The wrangle one fits the best under the passenger seat.(rear heater side panel) I like the features of the one that Chris used the best, but it's also the largest and not likely to be very user friendly to wire up in the location I want. The glass fuse type Drew has there will probably fit pretty good as both the + and - accessory posts are on the same side. But then I've got to have two types of fuses with me. I really like that with BlueSea you can order custom labels.
I'm leaning towards the glass fuse on though. Fuses don't take up much space and I think that one will fit where I want it.
Old 02-28-2008, 05:05 PM
Shark Bait's Avatar
You know, I went by West Marine today again. I had thought about it a little more and went ahead and bought a 6 glass fuse box for my project 40 and 6 blade type box for my 80. I think I can make do in the 40 with 6, and the idea of using the same type of fuses appealed to me. Of course he 80 has the blade type.
Damn, wire is expensive. I picked up an already cut length of both red and black 2 ga. and even with a 30% discount it was $4.59/foot. I went with 6 ga.
'12 GX460
Old 02-28-2008, 06:07 PM
Yeah, copper is way up. JB Saunders has good wire selection, but the price is average.
Drew
  #24
Old 03-15-2008, 02:07 PM
Corbet, this thread might help some --> http://www.risingsun4x4club.org/foru...ead.php?t=3567
Starting with post #31 there is discussion on adding a second fuse block with some helpful information on wiring size etc. As for amp ratings once you have the fuse block installed then you can wire up and fuse the individual circuits at the appropriate size for what the device requires. How big of a secondary fuse block you need (max amp rating, max # of circuits, etc.) is determined by what all you are planning to add. I would suggest going the next size up to allow for growth (i.e. you plan to add 3 ckts then go for a block that will support 6 or more ckts)
HTH
The wiring chart did not go as high as my fuse block is rated for. (80 amp) with a margin of safety I think I'll put a 60 or 70 amp circuit breaker on it. Something like this under the hood. Its waterproof too.
http://www.westmarine.com/webapp/wcs...9&classNum=119
What does the forum say for wire? 6 or 8 awg? Probably have to run 10-12 feet. Battery to fuse block under passenger seat. I know bigger is normally better but harder to run in tight spaces and more $ too.
  #25
Old 03-15-2008, 03:31 PM
for 10ish feet I would think 8 is fine!
  #26
Old 03-16-2008, 05:52 PM
Corbet,
IIRC when I was looking at this stuff last year (yeah, I still haven't got it done) I came up with needing 6ga to run from my battery (DS) to the fuse block under the PS (planned location).
I couldn't find 6ga wire . So, IIRC I bought 4ga from Mitek...maybe it was 8ga...I think I figured the run at >10-12' though. Are you running from a second battery or the main battery on the DS?
This site seems to recommend 8ga for up to 100amps and 4ga for up to 150amp. It also shows (if I'm reading it correctly) that for 600 watts/96 amps you'd need 4ga wire for a run of 8' or more...
  #27
Old 03-16-2008, 06:19 PM
I found this chart that seems to confirm 8 AWG should be OK. But I'm no EE, Romer chime in here.
http://www.powerstream.com/Wire_Size.htm
  #28
Old 04-14-2008, 07:02 PM
Default Did the install this weekend
Blue Sea fuse block, part # 5015
Blue Sea circuit breaker 60 amp, waterproof, part # 7111
West Marine double 12v outlets, part # 6867915
Heat Shrink tubing from Northern Tool
All wire/connectors sourced from Ebay vendor: http://stores.ebay.com/Genuinedealz
6/2 awg, marine grade
10/2 awg, marine grade
12/2 awg, marine grade
Closed End Tinned lugs
10-12 awg waterproof heat shrink ring terminals
Also installed, Kenwood TM-v71a Dual Band HAM Radio
The complete system is very overkill as far as wire gauge verse power demands. My goals were to minimize voltage drop, allow for future expansion, waterproof as possible, and maintain the cleanest possible appearance.
First up the fuse block. I choose the glass fuse type block from Blue Sea because of the mounting holes. I was able to use the factory screw for one. Blue Sea also offers a modern blade type fuse block but IMO this one fit better.
I followed Slee's example and placed it under the passenger seat on the side of the heater. Power is suppied by 6/2 awg from the battery. 10/2 awg goes to the rear 12v outlets, 12/2 awg to the front 12v outlets. Used the supplied Kenwood wiring harness for the HAM
  #29
Default 12v Outlets
12 volt outlets installed into passenger side of center console and in the rear below ash tray. 10/2 awg run behind interior trim to rear outlets.
  #30
Kenwood TM-v71a. Radio placed under drivers seat. The mounting bracket had to be modified in order to lower the radio to clear seat mechanicals. The control panel is installed into the back of the center console. I first removed the fake wood trim with a heat gun and gasket scraper. I cut the hole with a Dremel tool. Right now the fit is tight enough that I didn't have to make any kind of bracket. I need to find a better way to cut plastic and then reinstall the wood trim. Antenna coax is run under the carpet to the door sill trim where it continues to the back hatch mount.
