Old 02-24-2008, 10:09 PM
Default the definitive snorkel thread.
Wes said something in Treeroot's Ptarmigan thread that reminded me of one of the discussions currently taking place in my head, so I wanted to start a separate thread to hash this out. I am getting real close to doing the Landtank MAF sensor mod. I'd like a little more power, but hopefully better fuel economy, so "more air" seems like the right direction. But no, I'm not giving up manifold cooking or the York, so we'll be sticking with the naturally aspirated options. However you tell me if that matters here.
Pros of the snorkel:
-Cooler, cleaner air intake since it's up higher.
-Ability to consume more air.
Cons of the snorkel:
-Have to drill a big hole
-Idiot magnet
-More drag?
The Toyota OEM snorkel looks like this:
Old 02-24-2008, 10:11 PM
The Safari Snorkel looks like this:
Old 02-24-2008, 10:17 PM
The intake hole for the OEM one is right where the power antenna is (on an 80) so you will either need to remove that, or try to relocate it. With the Safari, the intake hole is further up the fender, so you can keep the antenna in the stock location but you need to melt a little reveal in order to insure continued smooth operation. It also looks like you give up the "ram air" effect with the OEM snorkel, since they've got that big satellite dish/prefilter deal on there.
I don't plan to/expect to cross deep water with either option. My main reason would be better performance, even though that discussion seems to go around and around and get no where. So someone who's done more research than me set us straight here...
Old 02-24-2008, 10:18 PM
Because the radar dome kicks a$$. OEM rocks. That is all.
The oem has a precleaner. You're not going to get any ram effect with it.
Old 02-24-2008, 10:31 PM
Nay's Avatar
Nay Nay is offline
I like the Safari look much better. As for performance, I think it's mostly "seat of the wallet", as in "I just spent a bunch of money and I know it made a difference".
I'd get the Landtank MAF mod and do the snorkel if you like the look. I did think it made a difference on my old XJ, but it's really not a "performance difference" in the sense that you'll still bog down on the same hills as you do now. The Landtank MAF mod has other benefits, and dollar for dollar I think it's a no brainer. Except that you don't get a "periscope"
Old 02-24-2008, 10:37 PM
Romer Romer is offline
Having installed one on an 80, The Safari has a straight shot down and then a larger rubber hose going straight into the aircan. What I aw of the OEM goes in where the antenna is and then out to the air cleaner where the Safari is, so another 90 degree turn maybe cutting down airflow. Does it really matter because it can only take so much air? Haven't a clue.
I will tell you getting the bolts on that part where the antenna is located is very very tight and my arm was bruised as far as I had to shove my arm in there. That was just to get 1 bolt. I would ask someone who has done OEM how tight it is getting that setup in. It's obviously doable, but I would think more difficult than the Safari.
I think there was a thread where someone took the top part of the OEM and fitted it to a safari, That might be worth doing and I might go for a group buy on the top part to play with it.
What I did on the Safari, is found the cheapest online price and went to 4wd parts who matched it. Christo gets my money for bumpers, drawers, sliders, frigs etc. I have no problem with saving a few bucks on something sold everywhere.
Old 02-24-2008, 11:00 PM
Shark Bait's Avatar
-Idiot magnet
-More drag?
Once more "con", having to repeatedly hear,"What's that thing?".
'12 GX460
Old 02-24-2008, 11:04 PM
I think that was the idiot magnet part...
So do Aussie 80s not have radios? 'cept'in' for VHF/UHF?
Thats the idot magnet part
Here is an interesting hybrid
http://forum.ih8mud.com/80-series-te...-question.html
I would think the nature of it would provide less airflow but then again, at what point does it matter?
Old 02-24-2008, 11:07 PM
So if you guys agree the only two benefits of a snorkel are cleaner air and more air, and you agree that OEM is less air than Safari, then only reason to pick OEM is looks?
I'm definitely starting with the MAF mod first, then see where this goes.
