Old 02-25-2008, 02:15 PM
timmbuck2's Avatar
Default 3 speed vs 4 speed pics?
OK, been searching on Mud and Google and SOR and various places, and do not have a definitive picture of the differences between 3 speed and 4 speed trannies and tcases. Any hints? Could be helpful as I search for the elusive 4 speed tcase...
Thanks.
T
* 00 LC
* 99 Saab Convertible
* 76 Piggie
* 1996 T-100 with 396k miles
has a 2008 FJC
KDTIM
Old 02-25-2008, 02:34 PM
Does the 3spd tcase have an aluminum housing like the 4spd?
Old 02-25-2008, 03:02 PM
treerootCO's Avatar
Event Coordinator
Thanks.
T
A three speed transmission is the size of a cantaloupe. A four speed transmission is the size of a watermelon.
T-cases are all spec-ed out here:
http://www.ih8mud.com/tech/cases.php
and
http://www.kinzers.com/don/landcruiser/tcase_tech/
and
http://cjford.stormloader.com/Tech/transfer1.htm
and...
yes
www.root45.com
www.risingsun4x4club.org
TLCA #14133
Old 02-25-2008, 03:21 PM
input cutout on the bellhousing on a three speed is round, 4 speed is peanut shaped
Old 02-25-2008, 03:31 PM
timmbuck2's Avatar
does that mean the tranny itself has a difference?
ok, thanks for the links Root, but I am more confused now. (big surprise) As I understand it, I would need a "4 speed" tcase to work with my 4 speed tranny...the pics from the links show 3 "3 speed" tcases and 3 "4 speed tcases" and show the differences between a brittle case and a softer case, and between a 3 speed case and a non-USA case, but the 70 - 1/75 (3 speed) case looks exactly like the '74 - 7/78 and the 7/78 - 7/80 4 speed tcases. What obvious thing am I overlooking here? Thanks.
T
* 00 LC
* 76 Piggie
has a 2008 FJC
KDTIM
Old 02-25-2008, 04:11 PM
Yes.
If you are going with a 4 speed tranny. Any of the cases will bolt up. The earlier 3 speed requires a different bearing and some adjustment. Zepp notes all this in his engine refresh thread.
4 speed
http://www.nis-photo.com/mudbay/_MG_6259.jpg
3 speed
http://forum.ih8mud.com/919570-post6.html
Old 02-25-2008, 10:21 PM
timmbuck2's Avatar
sorry, I meant that does the tranny itself have a circular piece vs a figure 8?
Yes.
4 speed
3 speed
* 00 LC
* 76 Piggie
has a 2008 FJC
KDTIM
Old 02-25-2008, 10:35 PM
Yes on the 4 speed input shaft end it's more of an 8.
Old 02-25-2008, 10:47 PM
Shark Bait's Avatar
Timm, You're still welcome to my 4-speed t-case shell. It was set up with 3-speed gears when I took them out to put them in my Orion. So the idler gear should be "set". And my offer is still good for helping you put some 3-speed gears into the 4-speed case if you get the rebuild kit and the conversion gear kit. The only other thing you will need besides a gasket to go between the tranny and the transfer case is the bolts for the 4-speed t-case to bolt to the 4-speed tranny. I don't have any extra of those.
'12 GX460
Old 02-25-2008, 11:10 PM
Shark Bait's Avatar
Bring it over here. I even have a parts washer.
'12 GX460
