Old 02-26-2008, 05:07 PM
Zepp notes all this in his engine refresh thread.
That would be here.
Old 02-26-2008, 05:11 PM
Originally Posted by nuclearlemon View Post
input cutout on the bellhousing on a three speed is round, 4 speed is peanut shaped
Below, a 3 speed housing is on the left, 4 speed on the right.
Old 02-26-2008, 05:16 PM
Originally Posted by Shark Bait View Post
The only other thing you will need besides a gasket to go between the tranny and the transfer case is the bolts for the 4-speed t-case to bolt to the 4-speed tranny. I don't have any extra of those.
As I discovered when I did my 4 speed tranny to 3 speed t-case conversion, you will also need a spacer for the tranny output shaft so the washer and bolt will fit, and you *may* need a spacer for the PTO gear if the t-case originally had a PTO gear.
I had a number of "gotchas" that came up during the install which I had never read about or heard about before.
