  #1371
Old 03-17-2014, 12:08 PM
Originally Posted by smslavin View Post
Clean NY title located in NC - that's not suspicious or anything...
Rising Sun Bio
  #1372
Old 03-18-2014, 03:34 PM
OilHammer's Avatar
Maybe just needs some updated paperwork. 88 is legal by year alone.
1966 FJ45 lwb stock
2003 100 OME lift
KD0PZL
  #1373
Old 03-18-2014, 05:48 PM
imhighlander's Avatar
Cool FJ45 in Louisville. Anyone on here?
Found a nice FJ40 in Carbondale.
___
TLCA #22433
1993 FZJ80: the Green Chile
  #1374
Old 03-18-2014, 06:39 PM
L43dean L43dean is offline
Default I half expect the bezel to be wrong side up; but...
What's up with front axle in photo #14 of the Fj-45!
  #1375
Old 03-18-2014, 07:51 PM
What the?
Nice catch Dean! That's pretty bizarre.
  #1376
Old 03-18-2014, 08:23 PM
Default How many C/V's bolted together is this gonna take?
Originally Posted by MDH33 View Post
What the?
Pondering this while warming some tortillas I think I get it. Spring over an OEM spring under and now this, my spring perch's are on the wrong side, so just rotate the axle! The cut and rotate back again is in the next phase. I need to go work on my own rig.
  #1377
Old 03-18-2014, 10:25 PM
AKcruiser's Avatar
AKcruiser AKcruiser is offline
OK Ill bite...
It appears that the photo is taken from the back axel looking forward. Shouldn't there be a driveline sticking out of the back of the front diff?
  #1378
Old 03-19-2014, 08:52 AM
Originally Posted by AKcruiser View Post
OK Ill bite...
Yup.
  #1379
Old 03-19-2014, 09:14 AM
MTSN's Avatar
MTSN MTSN is offline
I wonder if he has vibes with that front pinion angle
Current: 2014 200 series
Former: 1998 100 series
TLCA# 22666
  #1380
Old 03-19-2014, 09:24 AM
It's got a mini truck rear axle with a centered diff in it. There is no shift lever in the cab for the transfer case which makes me think it might not have a transfer case. The front axle has a cover bolted on it rather than a differential.... It's a two wheel drive truck now.
HTML code is On
