  #711
Old 12-01-2011, 12:51 PM
Originally Posted by rutbeer View Post
Negative. I have been regularly using mine to haul pallets of 80lb bags of mortar. That's 42 bags on a pallet! It definitely flattens the springs, but no signs of stress to the frame or axle. Even the michelins on it are rated at WAY higher than 1/4 ton.
3360 lbs. 1.68 tons not including the weight of the body.
  #712
Old 12-01-2011, 01:58 PM
Weight rating for Military trailers is normally the approved weight off highway.
My M101 (3/4 ton) has 2 ratings on the info tag. 1500lbs off road, 2200 HWY. And I have greatly exceeded that many times. Probably 3000+ off road once Maybe there is even more beyond what the trailer can hold for the military but a certain level it will still preform at. Goes back to what the Jeep can pull again Just thinking out loud....
  #713
Old 12-01-2011, 02:09 PM
i was always told on the smaller units like the 416s, it's the weight it will hold and still float
  #714
Old 12-01-2011, 02:31 PM
OilHammer's Avatar
I should have clarified that mine is a Canadian version though. It's newer and heavier duty than the old WWII US versions. Still, for a tiny trailer, I totally abuse it and it keeps coming back. I originally bought it for wheeling, but quickly decided it was too heavy and loud for long trips. If you pull, then set up, then wheel, it's probably okay. If you are doing expedition style wheeling, I would leave it at home. For me, it was well worth the $600 bones I paid for it for how much use it gets hauling fire wood, gravel, soil, mortar, you name it, and it fits nicely next to the garage.
1966 FJ45 lwb stock
2003 100 OME lift
KD0PZL
  #715
Old 12-01-2011, 02:37 PM
That's another criteria I did not consider and makes sense. I did not consider it as my M101 has a hinged tailgate and will never float. I alway forget the little ones double as boats.... Chris should get one
  #716
Old 12-01-2011, 02:45 PM
WØREK
  #717
Old 12-01-2011, 03:55 PM
Old40Dog's Avatar
Old40Dog Old40Dog is offline
Guess I need to start looking for an electric motor too, just in case!
Dave K,TLCA#20150,KFØDOG,'69 FJ40-"Toyolet",'92 FJ80 {Isuzu diesel conversion underway} ,2011 Replica M416 w/RTT,'98 Taco Xtracab 4X4, Project='72 FJ40, '05 Passat TDI-DD.
  #718
Old 12-03-2011, 05:19 PM
Mine! Thanks.
  #719
Old 12-12-2011, 04:03 PM
'69 Toyota
http://cosprings.craigslist.org/cto/2740676954.html
  #720
Old 12-22-2011, 12:35 PM
Hey Patrol Man, what do you think this is worth.. http://denver.craigslist.org/cto/2759149069.html
and why do I keep looking at it.
HTML code is On
