Old 03-04-2008, 12:19 AM
Default Advice or a possible Press
The dilemma.
I have a fully disassembled mini transfer case sitting on my bench.
The last step is to remove the main shaft, which, according to Marlin and others, should be accomplished with a dead blow hammer, carefully and gently.
As you've guessed, no.
As is typical with all things old, this baby isn't budging with a 4lb sledge.
The issue is that the bearing that surrounds said main shaft is stuck nicely, as it likely should be, and that must come out with the main shaft, or so I'm lead to believe.
Any tricks or tips? I don't need the bearing any more, perhaps a long pipe against the bearing to drive it out?
And, if not, anyone in North denver/Louisville/Lafayette have a press?
Old 03-04-2008, 06:20 AM
powderpig's Avatar
I have Kevin's press at my house in the foothills of boulder if you do not find anything else closer to you. Have you tried a little heat on the case to see it the expansion of the aluminum will release the bearing? Home phone is 303-665-1101
Old 03-04-2008, 07:29 AM
lfd270ben's Avatar
lfd270ben lfd270ben is offline
10 ton press in louisville just pm me your number
Ben
Colorado
1961 Dodge Power Wagon Town Cummmins 4BT, NV4500, NP205, Dana 60's
SOLD! 72' FJ40 little red 40 with some extras
2008 Dodge Ram Mega Cab Cummins
18 foot P&J flat bed
Old 03-04-2008, 09:36 AM
12 ton in aurora.
I don't remember ever having to use a press to take a t-case apart. You might be missing a bearing retainer or snap ring somewhere.
KD0FDS
Stephen
Old 03-04-2008, 10:23 AM
Thats what i thought, missing a bearing retainer. But, I've gone round and round the thing, and don't see anything missing. Also gone back over the directions about 5 times, and I didn't miss any steps.
For those who have presses, do you also have pipes, or other hollow impliments to press over about an 11 inch shaft? I may just bring it up and be done with it, as I also need to press off the 2.28 gear, and i have a clamshell for it.
Old 03-04-2008, 10:38 AM
Crash's Avatar
Crash Crash is offline
20 ton (I win!) here in NW Denver near Sloan Lake. Be glad to help if I can.
Steve
Old 03-04-2008, 03:11 PM
Steve
Sorry to burst your bubble sir! Robbie didn't post the specs on mine!
Old 03-04-2008, 03:24 PM
Crash's Avatar
And neither did you, so, on published spec terms, I still win!! Yay me!
Old 03-04-2008, 03:51 PM
Going over to Robbies tonight unless something changes.
Thank you to all who offered!!!
Hes just closest to me.
Old 03-04-2008, 04:07 PM
OK you win!
