Old 03-04-2008, 01:26 PM
Default FT7800 remote mount quick fix
Don't want to spend $59 on a remote mount kit for an FT-7800?
I ordered a replacement part RA0539800 "SUB PANEL" from Yaesu directly. This is the panel on the front of the radio itself, that the face plate snaps into.
$1.15. Shipping will be $6-10 or so.
(If that bugs you, remove the sub panel from the radio and put plastic shims where the tabs used to be, and reassemble it. That's free.)
This will attach to a Ram Mount .5" ball and arm system suspended from my rearview mirror attachment point. That will be about $27, kinda pricey but they are uber cool and totally configurable.
I will use CAT 5 cable to run down to the radio under the headliner.
Still have to figure out how to suspend the mic and cable without irritating myself or my .
On Line manual for the FT-7800:
http://www.radioamateur.eu/schemi/FT7800R_serv.pdf
KDØRCH
Old 03-04-2008, 01:54 PM
Bill: don't use CAT 5 cable.
Go on ebay look up seller W1Jim and buy the Yaesu cables (extension & aux audio extension) for $11. All high quality, 25'- more than enough.
Here it is, ready to buy.
Originally Posted by nakman
Old 03-04-2008, 01:58 PM
I didn't use the sub panel at all. I put some heavy-duty velcro on the back of the faceplate and mounted it to my console for a slimmer fit. I thought it looked better. And if needed, it is still very easy to remove for security purposes.
The sub panel is still in the front of my radio.
Old 03-04-2008, 02:13 PM
Thanks for the lead on the cable, Matt.
There is NO room on my dash for anything though. The faceplate holder is pretty much required for my uses.
BTW- why not use CAT 5? It was Dave, or Brian (can't remember) that said not to use phone cable, use CAT 5. Or... I am dreaming. Always a possibility.
KDØRCH
Old 03-04-2008, 02:21 PM
Don't know if there is any reason to not use Cat 5, but the cord you get from this guy will lay flat under your headliner.
Old 03-04-2008, 02:44 PM
How about these versions of faceplate holders? Not trying to talk you out of anything...Just throwing out options I've see
IMO, I don't plan to leave my faceplate visible very often so I want something that is easily removable although I'll probably go with Matt's velcro idea
Vent mount
Dash/Windshield mount
P.S. You are putting your rig under the headliner
Old 03-04-2008, 03:06 PM
Yes. *Just* below the headliner. Mounted on a small Ram mount hanging down from the mirror base. The base unit will go under the driver's seat, or perhaps behind a side panel. I have room there too.
The suction cup mount is a possibility (Ram mount makes those too), but I really want something more solid and out of the field of vision, yet visible. Hence, the Ram mount. http://www.gpscity.com/search-a+ball+size
KDØRCH
I got a vent mount very much like that with my Sirius Stiletto 2. I was not impressed. Good way to break your vent IMO.
Old 03-04-2008, 04:30 PM
Wasn't me, CAT5, plain old twisted-shield phone, whatever. Seems like it would all work fine to me. I dunno.
Old 03-04-2008, 07:26 PM
Tramontana Tramontana is offline
Default Will heat build up be a problem...
...if you bury your base unit under the seat or behind a side panel?
I'm just speculating how much other "stuff" gets shoved under our seats, and behind a panel would pretty much prohibit any air cooling of the radio?
Sounds like good ways to overheat the equipment. But I really don't know squat about this stuff yet. Maybe these are tried and true mount locations?
What is the ideal location?
Cheers!
