  #51
Old 06-06-2009, 10:56 PM
Thanks guys - Interesting stuff
  #52
Old 08-11-2010, 08:06 AM
rhyary's Avatar
rhyary rhyary is offline
I can't see this link. My user id is not authorized to see this one:
http://www.risingsun4x4club.org/foru...ghlight=setups
Can one of the moderators help?
Rami
96 LX450
Albany, NY
http://bestcamptable.com/
KD2KDK
  #53
Old 08-11-2010, 10:04 AM
Rami
Rami,
That link takes folks to the Members Only section of the forum which unfortunately you don't have access to...You could join the club
I looked through the thread and there isn't much there that isn't here in this thread and other threads in the HAM section...I bet if you looked at Romer's ROTW posts on MUD you'd probably see most, if not all, of what is in the thread.
  #54
Old 08-11-2010, 11:00 AM
rhyary's Avatar
Tnx, Jeff.
My 350R stopped transmitting. I can hear very well
When I do radio check with a local repeater, people on the net say that someone is trying to transmit but they can not tell who it is.
So my conclusion for now is that the antenna got whacked somehow. The mag comes with the think coax and it is possible the door got it kinked.
So I went a head the ordered the Diamond setup for the trunk gate.
It comes with the thin coax and it folds as well.
Here is my antenna order in case you guys see something fishy (I got the tri band antenna):
K400C - mounting setup with thin coax
CR-320A - triband 2m, 440, 220
SBB-1 - short dual band for our NE trees.
Rami
Counting the days to Moab 2011.
96 LX450
Albany, NY
KD2KDK
  #55
Old 08-11-2010, 11:51 AM
me thinks its a setting on the 350. I have the same radio and I was able to talk to nathaniel on the CC on the way to moab but coming back I was having issues. I haven't looked into it much but I need to get it working. I think with mine though no one was saying they were hearing a transmit but no voice.
  #56
Old 08-11-2010, 12:02 PM
Tone offset or whatever it is got changed? Sorry, still a HAM noob but I know when I first got my HT and started using it I spaced out the fact that although you can hear folks on the repeater, if you don't have the tone or what not set up right no one can hear you. Although maybe the fact that others were hearing the "break" means that this isn't the case.
  #57
Old 08-11-2010, 12:10 PM
  #58
Old 08-11-2010, 12:12 PM
Ahhh...
You were probably looking for the parts "list". Here is the pertinent info from the thread:
FT-7800R -- Yaesu FT-7800R 2M/70CM Dual Band FM Transceiver. Wide Receive of 108-520MHz and 700-999MHz (Cell Blocked). NOAA Weather Alert. Illuminated keypad & microphone.
K400CNMO -- NMO Deluxe mount. w/6.5' RG-316 Teflon coax & PL259.
SBB-5NMO -- Comet 2M/70cm Mobile Antenna (Black), 3.0/5.5 Gain, 38" Length, NMO Connector
My setup is similar but the FT-8800, K400CNMO mount, and a Diamond antenna similar to the Comet (the Comet was on back order when I was buying).
I've been real happy with the mount aside from finding a reliable way to attach the thin coax to the upper gate to keep it in place and safe from getting pinched. The little doodads/clips that I've been using that have sticky tape fall off in short order when the tape gets hot, wet, etc.
  #59
Old 08-11-2010, 12:30 PM
rhyary's Avatar
I switched the order to NMO type. Changed the short antenna to a diamond antenna to stay with one brand.
Most of the repeaters in my area are open. No need for tone. But the mic has an option (button) to change the tone, so I may have pressed something in inadvertently.
Damn, it was working so well when first installed. But anyway, the mag was only temp anyway.
The only think that could have change by mistake is pressing something on the mic. The 350R comes with multi function mic that has many buttons.
96 LX450
Albany, NY
KD2KDK
  #60
Old 08-11-2010, 01:47 PM
rhyary's Avatar
Did system reset. Still no worky.
I really hope that the cable got pinched and somehow the new antenna will fix everything. If nothing else but to prove DaveInDenver wrong :-)
But I talked to Yasue tech support and he sort of echoed Dave's opinion. The TX got toast somehow.
I don't have a good confirmation from the guys on the repeater but if they did hear something than that means I am transmitting but not very good. That may point out to the antenna.
96 LX450
Albany, NY
KD2KDK
