  #61
Old 08-11-2010, 01:53 PM
rhyary's Avatar
rhyary rhyary is offline
The 350R has a mic in the faceplate and I tried that.
I have a repeater near by that when transmitting it, it just repeat back its signature. No one else involved. That is not working and it used to work when I got the radio.
In addition I am running APRS on one side and I can no longer see myself here:
http://aprs.fi/?call=KC2YRF-9&mt=m&z=11&timerange=3600
That was working fine.
96 LX450
Albany, NY
http://bestcamptable.com/
KD2KDK
  #62
Old 08-11-2010, 02:13 PM
rhyary's Avatar
Now that I think about it, something similar happened on my CB during CM2010.
I can hear everyone fine and clear, but when I was transmitting everyone was complaining about noise and squealing. It turns out that the ring of the PL connector was not screwed all the way. Once I tightened it, TX was fine.
Point is, and my hope is, that it can be the antenna/cable even if I can hear clear.
Doing simplex test at 5pm with a co-worker. Having the cars at close proximity should tell us something.
96 LX450
Albany, NY
KD2KDK
  #63
Old 08-11-2010, 03:23 PM
rhyary's Avatar
Good news.
Simplex worked up to about 1 mile. After that I heard great but co-worker started to loose clearness. By 2 miles I heard him loud and clear and he could not hear me. I guess.
So I would guess antenna or antenna wire. Will be replaced when the new setup is here.
Should be good to go for CM2011 :-)
Rami
96 LX450
Albany, NY
KD2KDK
  #64
Old 08-17-2010, 10:03 AM
rhyary's Avatar
Well, I installed the new antenna and same thing.
I also did a SWR test on it and no power is coming out of the 350R.
Yesterday it went to Yaesu for warranty repair.
Not Happy!
And yes, turns out DaveInDenver was right after all. :-)
96 LX450
Albany, NY
KD2KDK
  #65
Old 08-17-2010, 10:05 AM
Wow, bummer to hear that the radio is not working. Good to hear that you figured out what was up though. now at least you know all the in's and out's of the setup you have!
  #66
Old 08-17-2010, 11:32 AM
rhyary's Avatar
Nothing like troubles to get you familiar with your equipment.
I had run the 350R in the back seat for awhile and when I figured out all is good, I perma mounted it in the pass rear quarter. It worked for a while and some point it quit. I was listening for the repeaters around Albany but not transmitting. So I don't really know when it quit. Since I have the APRS, I can track myself and do a radio check that way on regular basis.
Monday I had a day off and worked on getting the 350R out of the back. I also took the time to run the extension properly in the pass side channel all the way to the front. Figure out a way to mount the the face plate. I am pretty happy with the location. I hope it is steady enough.
Back to Antenna topics. I got the 320NMO tri band for experiment on three freq. I also wanted a longer one for the tail. So I was about to get the Diamond 7900. I called Diamond tech support to see what they have to say. Well, they don't want the 7900 off road. The say that because the coils are loaded up high it will swing to much. So I got the 770 instead for the trail. It is open coil design 1/2 wave for 2M and 5/8 for 70cm. That should cover Moab and other expedition type trails, I hope. For the NE trees I have a short NR-72BNMO.
I mounted the KC400NMO on the trunk on the driver side per Diamond instruction. crossed-over and used the 10' extension to get to the radio. Since I only needed about 2 feet extension, most of the 10' is sort of coiled in the quarter panel. I have to see the implications of that when I get the radio back and measure the SWR.
I will load some pictures soon.
96 LX450
Albany, NY
KD2KDK
  #67
Old 08-17-2010, 11:52 AM
rhyary's Avatar
Default Installation Pictures
I am not happy with how the antenna cable enter the trunk. If you guys can make suggestion to make it better it will be great.
96 LX450
Albany, NY
KD2KDK
  #68
Old 08-17-2010, 11:57 AM
rhyary's Avatar
Default Installation of the remote plate
I took the console apart and stuck the windshield mounting bracket (just the rubber end into a hole I made in the metal mash. Because the plunger type bracket is pretty big, it is held by the plastic grid that is before the metal mash. That give me a strong mounting. the unit still rotated few mm when I push the buttons, so I stuck a small piece of rubber on both ends of the plate to give it support in the corner. time will tell if this is good. I am afraid passengers will bump it or with use pushing buttons the mounting will loosen up. Will see..
96 LX450
Albany, NY
KD2KDK
  #69
Old 08-17-2010, 12:58 PM
Mine runs underneath the light brown plastic, all the way up to the headliner. That would bury that connection you show behind the panel, and would look a little cleaner?
And are you using the lip of the cupholder as your mic holder?
  #70
Old 08-17-2010, 01:08 PM
Same here. Mine runs all the way down the pillar behind that light brown plastic, and then behind the darker brown plastic to my radio. The rest of the cabling runs up along the door sill to the front.
Will that connector fit behind the plastic, or is it too big?
