Old 03-11-2008, 09:40 PM
daisydog34's Avatar
daisydog34 daisydog34 is offline
Default Random FJ40 Questions
So im reviving Jethro's forty before Moab and am in the middle of doing a body swap. The chassis is a 68 and the new body is a 72. I have run across a couple of problems and me being a mini truck/runner guy am confused.
1. In the 68 body the pedals mounted to a "pedal bucket", the 72 doesn't have this pedal bucket. Im wondering what would be the best course of action here:
A. Cut out the old pedal bracket and weld it into the new body.
B. Order a new pedal bucket from SOR and weld that in.
C. Try to find used pedals from a 72ish body that would bolt in the new body.
2. The 68 had a vacuum shift system for the t-case and the lever under the dash. The 72 had a floor shift system so there are no brackets on the back of the dash for the shifter linkage to mount to do I:
A. Buy the SOR floor shift conversion kit.
B. Cut the old brackets of the 68 and weld them to the new body.
Im just looking for some input here, I could figure it out for myself, just thought I would see what yall had to say about the matters. Or if anybody had any experience doing this kind of a swap and if there are any other problems I will run in to.
Thanks in advance
Old 03-11-2008, 10:02 PM
Shark Bait's Avatar
If you look around you should be able to find a complete pedal bucket from a parts cruiser. SOR lists 7/70-7/80 as the same part.
You should be able to get later "floor shift" parts from a later cruiser as well. SOR sells a kit for $289.
www.sor.com
IMO it's easier to find the newer parts than cut and weld. My .
'12 GX460
Old 03-11-2008, 10:39 PM
can't help you on the pedal bucket as i'm too lazy to go out and look at my 60's vintage cruisers, but on teh trans...scrap the three speed and find a four speed setup. floor shift and more comfortable tranny.
Old 03-12-2008, 12:11 AM
daisydog34's Avatar
Are the pedals themselves and how they mount the same in 68 as they are in 72? I guess what im asking is can I order just the pedal bucket from sor and use my pedals or will I need new pedals? Am I following this correctly?
As for the three/four spd. It has an SM420 in it which is great gotta love that low gear!
On a side note, Toyota did some really strange things back in the day. Like I said earlier I am a runner/mini guy my baby is a 4runner. Everything from the wiring to the fact that the transfercase just hangs out behind the tranny that just hangs out is WEIRD!
Old 03-12-2008, 06:19 AM
Shark Bait's Avatar
Not sure, but they might be different. If no one in the club has a complete bucket there is IH8MUD and Classic Cruisers. You could also try Ron at Rocky Mountain.
Whatever you do you will have to adapt it because of the SM420.
'12 GX460
Old 03-12-2008, 09:22 PM
When I did the 4 speed conversion on my 71, I kept the vacuum shift because I really, really like it better than the floor shifter for the t-case. Plus it was less work :-)
